The chain brake probably needs some adjustment or replacement parts and if you need to ask you probably aren't competent enough to deal with it.
A chainsaw is a potentially lethal piece of equipment with little room for error either in use or in the maintenance. You should take your saw to a specialist...
is it possible that the needles are in backwards? it's very possible that the machine is out of time & would have to be taken to a sewing machine repair shop to be retimed
if you loosen the nuts holding the bar on there is a tension screw on the opposite side from where the nuts are you should see it if you look from the front of the saw by the muffler you need to use it to put the proper tension on the chain if you turn it clock wise it should move the bar out tightning the chain you want a tiny bit of slack in the chain it should not be dogged down tight with the tension screw if you go counterclock wiseit should release tension. once tight tighten screws to hold on bar and spin chain by hand should be able to spin chain if not it is to tight. hope this helps
You may have a locked up wheel bearing or you may have an object stuck in the chain. Can you spin rear wheel by hand? If not, most like bearings, if so, then you may have bent gear tooth or something stuck in chain. Check derailer to make sure it is not bent
