SOURCE: Our Samsung RF265AB (bottom freezer) is leaking
have a water tank or line leak for water dispensor
SOURCE: I have a Samsung RFG297AABP
Hi.
If the leak is not too big, then water comes from condensation. Water condensing inside the fridge is supposed to be conveyed toward the drain hole inside the fridge. From there the water should normally go to the drain try located in the compressor assembly.
What usually happens is that the drain hole gets clogged with frozen water, and the condensed water ends at the bottom of the fridge. The problem is fixed defrosting the fridge. In some sporadic case it is necessary to remove drain hole blockage using a thin and flexible drain rod.
Do a complete defrost, that should fix the problem.
Here all parts and diagrams for this fridge.
Regards.
Ginko.
