SOURCE: My 5 hp, 25 Gal. Craftsman air compressor is
It sounds like your intake valve is worn or defective. Take the head apart again and look to see if the valve is sealing properly. If you post a comment with your model number I can look up the specific parts at sears parts.
If your compressor is functioning properly, air should not come out of the intake muffler (filter)
Thanks,
Tim
SOURCE: My craftsman 25 gal. 5 hp. compressor builds 120
Replace check valve the piston is getting stuck sometimes alloying the air to leak all the way down till it comes back on
SOURCE: My craftsman air compressor model 919 16737 1.1 hp
Probably the check valve has failed. It apparently is where the pipe goes into the tank from the compressor.
SOURCE: Craftsman 3 gal., 1.5 hp air compressor: won't
The compressor will not auto shut off until it reaches the preset pressure which is usually around 100-130 psi - your problem is leakage of air from the oil filler cap suggesting that you have a failed internal valve.
SOURCE: I have a 3 gal 1 hp model 921-153101 and i was
sounds like a valve broke and you need to replace the valve plate.
http://www.mastertoolrepair.com/sears-craftsman-921153101-p-24902.html?osCsid=ke90vvsu0rof263nthcsf9e9a1
