Refrigerators Logo
Posted on Apr 19, 2009
Our GE TFX22PPDA started oozing a sticky brown substance from the bottom left corner of the freezer door. We defrosted the freezer and cleaned out the drain. Next we checked the drip pan under the frig, which is full of brown water (source?). The door is still dripping. What do we do?
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Sep 26, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
623
Points
I have a GE refridg. and a light, brown sticky liquid periodically drips from the water dispencer panel area. This started after we lost power for 5 days. What to do??
2answers
Are "door open" alarm won't stop beeping.
Try disconnecting the power at its source, then reconnecting it.
I have a 2004 GE Monogram zisw420dmc refer. There are often small drips on the floor under the lower left and right corners of the freezer door. The fiberboard and stainless door cover have become damaged...
The drain in the freezer behind back lower panel
needs opening. You can see it at the bottom of the back panel
underneath the evaporator coils. (The cold coils)
Run Hot water in the drain until it clears or use a hairdryer.
When the defrost melts the water it goes down the drain
If the drain is clogged with Ice or ? The defrost water
overflows into the ref. or freezer or on floor
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
If you need more help GO HERE:
http://www.applianceaid.com/procedures.html
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME IF THIS WAS HELPFUL
My refrigerator was leaking a brown substance that drained down the back of the refrigerator to the bottom. What is this brown substance and how can it be fixed?
Leo Ponder
imufo2
Hi. Fridge freezer, bottom of freezer freezes and door stick,s many people have had this problem any cure any cure for this. thank you Mr R Burrell
Check to see if there is any ice forming in the freezer in the bottom. You may have a clogged drain and the water is backing up. Also check to see if the door seal around the freezer door is sticky, if so clean with something that will remove sticky substance. You may have spilled something on it.
A few days ago I noticed that the bottom of my freezer side of the fridge was covered in about 1/2 inch of ice. It goes all the way from the back of the freezer up to where the door seals...and the door...
its not doing a defrost by itself you need to replace the defrost heater/defrost termination sensor/thermostat/defrost timer could be any one of these parts causing this problem you need to test each part with a multi-meter to determine what needs replacing.
Need help on freezer build up and freezer not getting cold
try defrosting it manually. unplug it and let it sit with the doors open for about 4-5 hours and make sure the doors close and seal all the way.
2answers
FROST BUILD UP IN FREEZER AND REFER NOT COLD ENOUGH
hello.
  • Defrost the freezer
  • Clean the condensor coils
  • Check the door seals
  • Test the door switch
  • If you recently adjusted the temperature control, loaded the refrigerator or are in a humid location, it is not uncommon for a refrigerator to run for 24 hours or more before getting cool.
  • 0helpful
    Upright freezer is leakng from the bottom of the door
    pull out lower bin and check at back to see if you have ice build up. if you do the defrost drain tube is blocked
    2answers
    GE Side by side runs constantly.
    The timer that controls the defrost cycle/function, may have failed and there may be no defrosting occurring. If icing of the coils due to the missing defrost cycle, there may not be enugh circulation left to keep the thermostat happy.
    Try defrosting it manually (I know, it's a pain - aren't we spoiled?) and see if the compressor then cycles for a few days before it starts running continuously again.
    And for Dr. Fred, the above suggestion about trying manually defrosting applies to your problem too.
    The exposure to overnight moisture (ice accumulation) may have interfered with the automatic cycle.
    Ge profile leaks from front of freezer
    your drain will be plugged under the tray. there is a hose that runs to the drip tray. the back cover comes off you can then get at the hose
    Top Refrigerators Experts
    vince
    Johnny 1000
