I have a Sansui TV and I have a REM350 Remote I was wondering if you could give me that info please thank you.
I had the same problem with my REM340 remote trying to program an older Zenith TV. Here is what I found and it worked pretty quickly.
Turn your TV on.
Press and hold the SET button until the light stays on.
Then press the TV button.
Then press the VOL+ button until your TV turns off.
Once your TV turns off, press the SET button again.
Hopefully you can now turn your TV back on and everything will work. Good luck. I know the frustration.
I seem to have lost the code book to the remote I have the code I just need the instructions on how to put the code in and maybe the proper code for proscan and how to obtain a full list of codes
need program instruction and code for a toshiba tv
