Garden Logo
Posted on Apr 19, 2009
Pressure washer stalls out when wand nozzle is released
Cannot pull start cord unless wand trigger is depressed. if I release wand trigger while pressure washer is running the engine stalls & shuts off
  • 1 more comment
  • dcroft54 Apr 20, 2009
    where is unloader valve & how do I get at it
  • Anonymous Mar 16, 2014
    Just bought a 2350 simoniz power washer used in great shape, what i thought......anyway runs great, low pressure good and when you pull back on wand for high pressure nothing comes out. Seems end is clogged with debris. I unscrew the half wand and blow through it but nothing comes out. Should u be able to blow through when wand is in high pressure and how to clean
  • Anonymous Mar 22, 2014
    engine runs fine, when wand trigger is depressed, no flow out of wand. hose is clear
Anonymous
Level 1:
  • Contributor 10 Answers
  • Posted on Apr 20, 2009
Anonymous
Contributor
Level 1:
Answers
10
Questions
0
Helped
20918
Points
35
Common for not starting unless trigger engaged as you are turning the pump as well as engine creating pressure,as for stalling pump has unloader valve which is probably in need of grease(use good silicone grease)this allows water to ciculate when trigger released.
  • Anonymous Apr 22, 2009
    not sure wht type pump you have but most are located behind either adjustable screw or behind screw in cap on pump located close to pressure area.saw a small electric type which had to be stripped completely mainly due to compact size of pump.hope this helps
  • Geezor Jul 09, 2012
    Thankyou for the help! I just finished putting together a powermate pressure washer and now because of this solution I can sell it and make $200!
2answers
Karcher 2000 psi gas 4.0 HP troubleshooting
Have you tried servicing the motor. Fresh air filter, new fuel filter and a fresh spark plug? That will help narrow down what the problem could be.
1helpful
Replaced unloader in Karcher HH2400, now unit will not start unless I depress wand handle and pull start engine.
Maybe press regulator was reset before the unloaded was installed and needs to be set at lowest and then increased as needed.
No pressure on my husky power washer 1650
Basic Issues As an electric-powered washer, a circuit overload may cause your Husky 1600 to shut down or prevent it from starting. In this case, check your home's electrical service panel for a tripped breaker or a blown fuse -- the 1600 requires a dedicated circuit rated at a minimum of 15 amps. To prevent a blown fuse, avoid using other large devices on the same circuit as your washer. If you use an extension cord, it must be rated at 15 amps as well. Before moving on to more complex troubleshooting measures, check the gun safety trigger and release the lock if your 1600's trigger will not move. Water Woes Releasing air from the pump serves as a simple fix for low-pressure water output; remove the wand and allow the washer to run as you depress the gun's trigger until the water output normalizes. If your water output seems to lack detergent, ensure that the clear tube is securely connected to the detergent nozzle. Likewise, check the connected water supply and make sure the faucet is fully open and that there are no kinks in the hose to ensure optimal pressure. Using a shorter garden hose makes for stronger pressure, as well -- Husky recommends a hose with a maximum length of 50 feet for a city water supply. Clearing Clogs If your Husky 1600's pressure seems lacking or its water flow is obstructed, clean the nozzle by removing the wand from the gun, clearing the nozzle hole of obstructions with a stiff wire and flushing the nozzle with clean water. Similarly, clean the washer's inner water screen, located behind the garden hose connector, by removing the screen and flushing it with water. This also corrects low or irregular pressure and may remedy a unit that does not stop releasing water when the trigger is released. Model HD1600 features a chemical solution reservoir with a similar screen; clean this screen in the same fashion if you experience chemical intake issues. More to Consider If your power washer issues go beyond troubleshooting basics, contact Husky's customer service department at 800-381-0999. Husky recommends contacting customer service when your 1600 has problems with its pump, bypass valve, discharge valve or manifold assembly, for instance. Because this series of powerwashers was originally offered around 2001 through 2008, Husky's one-year limited warranty no longer covers the cost of replacement parts or repairs.
Sponsored Links
Sep 29, 2016 • Garden
Remove the hose and run the machine. If the machine works and the flow of water is ok. Start checking the hose for a restriction and trigger. Make sure this is correct before you start taking the pump to bits
1helpful
My 1750 psi campbell hausfeld pressure washer will operate at first until I release the trigger on the wand. Then it won't restart. If I wait for a while it will run again. Sounds like the pressure switch.
Common with that washer...it has a wabble pump. Release the trigger, if by pass does not engage, stalls engine. You can however keep using it, all you have to do is keep trigger pressed, and when you are cranking engine, depress trigger with the free hand. Can be repaired, but the fix probably will cost more than a new pump.
Oct 18, 2009 • Garden
2helpful
When I depress the handle on the wand the motor wants to stall
sounds like you have either a sticky unloader valve or a blockage causing back pressure to pump causing excess load to engine,a possibility is to check the nozzle at end of wand incase there is a piece of grit there since engine runs okay with no load,another solution is to check venturi that is located beside outlet of pump that you connect hose for wand to for possible wear or blockage,hope this helps
3helpful
Karcher 2400 psi blaster When you release the trigger it will not pick up pressure when you use it again
To determine if your problem is due to an easily replaceable part, follow these steps:
1. Connect the water supply hose, the pressure hose, and the wand WITHOUT any nozzle tip.
2. Turn on the water supply, and press the trigger until water is smoothly running out of the nozzle
after any air is all purged out. Release the nozzle trigger.
3. Start the engine, and let it warm up for about 30 seconds.
4. With the engine running smoothly, press the nozzle trigger. The water should flow out of the nozzle (without the tip installed) at a faster rate, while the engine noticeably loads down as it used to do before your "no pressure" problem. If it does not load down, turn it OFF, and disconnect everything, and contact a Karcher repair facility.
5. If the engine does load down, release the trigger, and install one of the nozzle tips (not the black one).
6. Press the trigger, and the engine should load down, and you should have normal pressure from the wand. After you release the trigger and press it again, you will probably again have no pressure, and the engine will not load down. Removing the nozzle tip, pressing & releasing the trigger, and re-installing the tip should give you normal pressure again, but releasing the trigger will cause no pressure until you again remove the tip, press the trigger, and re-install the tip.
This is caused by a bad UNLOADER VALVE, which is located under a black cap with a metal button on it located on the top front of the pump. I don't know if you can purchase the replaceable parts from a Karcher repair shop, but when a neighbor & I took his washer to a repair place, it looked pretty simple to do this repair, and he was charged about $60 to replace a $5 (maybe) part, and it took about 5 minutes.
There is no pressure
This is caused by a bad UNLOADER VALVE, which is located under a black cap with a metal button on it located on the top front of the pump. I don't know if you can purchase the replaceable parts from a Karcher repair shop, but when a neighbor & I took his washer to a repair place, it looked pretty simple to do this repair, and he was charged about $60 to replace about a $5 (maybe) part, and it took about 5 minutes.
Top Campbell Hausfeld Garden Experts
Jay Finke
Jay Finke
john h
Are you a Campbell Hausfeld Garden Expert? Answer questions, earn points and help others
