It fell of the bottom of your ice maker put your model number into repairclinic.com and you can find a pic or video that shows you how to put it back together
this particular model comes with an adjustable swing arm for ice prduction
pu the swing arm on the 2nd to last click
in the down direction
all the way down is off
I took the arm of the ice-making machine out of the slot and put it back in, pushing it snugly inside the slot, then raised and lowered it several times. Then, with the arm in the up (stop making ice) position, I felt inside the ice-making tray, where I noted there were ice cubes as well as a sheet of ice at the base of the ice-making tray. I poured approximately 24 oz. of hot tap water into the tray to melt the sheet of ice. I turned the freezer temp control to "warmer". I think the freezer temp setting was too cold, causing the ice maker to freeze the water before it could make cubes. I have a working ice maker again!
Cynthia
Ted, The arm should be down. The down position applies power to the control module... when the arm is up power is off. It's the opposite of a light switch.
sometimes when you pull the shelf in and out, it will bind on the shut off arm and cause it to "pull out" of the i/m module. the arm has to be put back into the back of the module. you can take the i/m out of the freezer or just use a mirror and look for the place the arm goes. it looks like a 1/4", round, white plastic slot. the arm just pushes into the white piece and thats what causes the i/m to shut off when full or when the arm is lifted up.
hi thanks for the question all the ice makers i have seen you can move the arm by hand so i would move it thanks cause it wont make ice with arm in up position thanks the appliance doc
sounds like you have 2 problems the arm being uop turns off the ice maker the water may be due to a clogged drain everytime it defrost the water should rund down the drain to the pan on the bottom and evaperate check the drain first
Thank you very much. This is exactly what I was looking for.
