1996 GMC Jimmy Logo
Steven John Glowacki Posted on Apr 19, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
4.3 vortec engine , engine noise, knocking or tapping on top of engine, not when cold , but starts noise when it heats up, and gets louder as it gets hotter and hotter!!! Sounds like noise is in the center of engine!!!!
  • Anonymous May 04, 2009
    i have a 98 v6 vortec it has allways had a timeing chain rattle at idle it is in a boat. it has 120 hrs run time. it seased i have it apart it spun a rod bearing closest to the oil pump i also found a badly damanged main 2nd from the front all other bearings look fine other than the bits of bearing material from the two that let go . the boat had 89 hrs i suspect maybe it has been run low on oil ie previous owner . also i found the drive gear on the cam that drives the balance shaft does not fit tight on the dowel. the hole in the gear is to big. i have two parts engines there the same thus cam timeing can be out. please help.
Bruce Bracey
Level 3:
  • GMC Master 1,000 Answers
  • Posted on Apr 19, 2009
Bruce Bracey
GMC Master
Level 3:
Answers
1000
Questions
Helped
623109
Points
3633
The knocking or ticking is going to determine if it is in the top end, lifters, push-rod or rocker arm issue or the bottom end that would include pistons or bearings.
If it is a ticking noise, it will more than likely be a valve train issue.
If a knocking noise, piston or crankshaft related problem.
Attached is a web site that you can listen to a piston slap which is a known issue for your 4.3.
Listen to the noise and see if it sounds similar to your problem. A piston slap will generally sound as though it is coming from the central area of the engine.
Listen to the recording and let me know.
Regards,
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on May 04, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
31123
Points
9
I just got a 2000 blazer with the 4.3L vortec (262) it sounds as if u r experiencing the same sound i was. i took it to a machnic because i thought it was the lifters. after having those replaced the sound was still there. i searched for months for answers and was finally tok it was the counter-balance shaft bushing. this was an annoying sound but i learned i could run it for a while with it like this. just make sure ur oil pressure is stable and put 1 quart of lucas oil and the rest a synthetic blend. let me know how it works.
bambam
Level 1:
New Friend:
Problem Solver:
  • Posted on Dec 06, 2014
bambam
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
Questions
0
Helped
31123
Points
I wanted to add my recent experience to this thread...I recently purchased a 94 Silverado with the 4.3L balance shaft design. 139k miles and 180psi on all cylinders. Loud rattling noise just over 1K rpms. After tearing down motor.. inspected anything that would create this noise. Upon removal of intake and inspecting balance shaft.. I could grab shaft and rock it back and forth almost duplicating the noise. Then when timing chain was removed and balance shaft gears inspected.. the balance shaft drive gear behind cam sprocket had hollowed out bolt holes and dowel pin holes! After numerous new parts.. oil pump.. rod bearings.. balance shaft front bearing.. balance shaft gears.. timing chain/gears.. heads redone.. new push rods.. all new gaskets. it still makes the noise however its not as loud. There is a fix for the newer motors with a new timing chain tensioner kit but is not available for first gen years!. The new balance shaft gear was clearly tight on the dowel pin now and it made a difference but not completely. Read that.. GM indicated that this was not an issue.. well if the cam bolts broke from the cheap balance shaft gear metal banging away on them it will be an issue!.
  • 5 more comments
  • bambam
    bambam Feb 20, 2015
    after driving this truck for about a month..I decided I cannot hande this rattling noise anymore! I am going to disable the shaft and install a different timing chain.
  • bambam
    bambam Feb 22, 2015
    update..removed balance shaft small gear..installed a single roller chain for A 99 4.3L and didnt feel any difference in idle vibration actually it was smooth! Noise is still present but 60% better..going to try new set of rocker arms before calling it quits! will do a motor for it later
  • bambam
    bambam Feb 22, 2015
    I ordered a double roller chain for the roller cam motors..IT WILL NOT FIT!! cam sprocket will grind into the block..you have to reuse the drive gear for the balance shaft.
  • bambam
    bambam Mar 04, 2015
    It appears that I had multiple noises inside this motor. I ordered new 1417-12 comps cam roller tip rockers..new rocker studs(make them adjustable) and permalocks by arp. I believe my remaining ticking noise is a worn rocker(s) arm. I have the nonadjustable style currently. I will update once I replace these items.
  • bambam
    bambam Mar 08, 2015
    replaced rockers and noise is still present..40mph..I am now leaning towards a piston issue..piston pin/side clearance etc.gm did a great job of installing second hand parts in these motors! other then cam/lifters..rest of valvetrain is junk..rod/main bearings look cheap..pistons arent quality made either.balance shaft design is useless. I felt slight difference in idle vibration after disabling shaft.I would suggest a high volume oil pump std for these motors! due to the wear in rocker arm lash and piston issues at a relatively low miles for motor.
  • bambam
    bambam Mar 08, 2015
    I wanted to add..I used a 99 single roller timing chain for this motor and it fit nice and tight! i originally replaced the stock chain with another and it clearly was junk. I noticed a big improvement from the roller chain.You cant use the chain tensioner on these motors either..wont fit unless you replace timing cover with newer version and then hope oil pan gasket fits too.
  • bambam
    bambam Mar 08, 2015
    it appears like my remaining engine noises are in lower end of motor..I am planning on replacing the short block (non-balance shaft) and retaining my top end.
Engine got a knocking cold start, silint when hot
It has developed a clicking engine noise on a cold start. After the car has warmed up, the sound goes away. ... Clicking or a sharp tapping from the valve cover on top of the engine would point to a valve train noise. A dull tapping or slapping sound from the side of the engine block would point more toward piston slap.4 Nov 2011
Cold-start engine clicking is a nuisance, not a disaster - StarTribune.com
2helpful
Possible lifter knock, been very cold here in midwest. runs fine in cold weather. warming up and i get a knock from engine. removed oil cap and does not really get louder ?? does go away and comes bac
Your hearing lifter noise common in most cars in cold weather I have a 2001 sc1 same engine as yours here's how to get rid of that ticking sound go buy a quart of Lucas synthetic motor treatment change your oil and leave it 1 quart low add the Lucas synthetic oil stabilizer within 1 week you will not hear the noise agian reason your hearing the noise is there's no oil at the top of the engine on a cold start oil when cold is thicker hints why your noise in your engine what Lucas does is eliminate the dry start by the way my engine has 288,000 and does not use a drop of oil after you use this product you should use it every oil change you will see your car will thank you regards Chris
Lost compression and now there is a loud knocking noise in my 454 vortec engine
Bent valves would be number one cause. Check the timing. If you lost time, your valves are tapping the pistons causing the knock. When the valves tap the pistons they bend and don't close all the way, so the cylinders cant make compression.
1helpful
2answers
NOISE WHEN COLD THEN GOES AWAY WHEN WARMS UP,SOMEONE SAID MAIN BEARINGS GOING BAD
Hard to say over the internet but I will try to explain. If the noise is a distict KNOCK KNOCK and it sounds like it is coming from the bottom of the engine, then it most likely is a rod or main bearing. If it is a TAP TAP noise that sounds like it's coming from the top of the engine, then most likely a valve lifer is failing/failed.
the fact that it goes away when the car is warm, makes me lean towards a bad lifter. Normaly if a bearing is bad and knocking, the noise doesn't go away.
The KNOCK noise will be somewhat hollow sounding and the TAP TAP sound will be more solid. If the KNOCK KNOCK is solid, then a rod or main bearing has most likely failed to the point that a new/reman engine will be needed.
1helpful
Engine knocking noise in 2000 saab 9-3 SE?
It's a common problem with these cars i am actually fixing mine as of now. That car is all about oil pressure and when it is low you'll start to get a tap and or what sounds like a knock due to the lifters not having enough pressure. Try taking your oil pan off and check your oil pick up line going from the oil pan to the turbo. A lot of times it gets a lot of sludge build up and makes the pressure little to none. If that looks clear check the slump inside the oil pan and see if that has sludge build up. Well hope this helped
2004 Cadillac Escalade knocking noise
Make sure oil level is adequate.
Also, this could be an exhaust leak that is being closed as the manifold and/or block heats up.
2answers
2000 jeep cherokee sport engine knock
could be rod with that amount of miles
7helpful
2answers
Engine make Knocking noise when cold
I have the same problem on my 2.0L 2001 Legacy auto. It began about 1000 miles ago. It has now done 84k. From my online searches this is most probably 'piston slap', and is not serious. To save weight Subaru shaved down the skirts on the pistons. With normal engine wear the pistons will at some point rattle against the cylinders until the engine is heated up and the pistons expand. The rattling should go away after a few minutes. If it persists say 10-15 minutes, it may be another problem.
1992 side kick
problem here is a ticking to one is a knock or a tap or a thud ect to others so of my experiance with engines if its a ticking that gets louder with the engine getting warmer its got to be the tappets its the only thing that would get louder if it gets louder when accelerating it could be ignition timming causes pinking most other things on engines that cause ticking sounds could be something catching fuel pumps cause a ticking noise but are not normally affected by engine temp yates210456
Top GMC Experts
ZJ Limited
ZJ Limited
john h
Thomas Perkins
Thomas Perkins
Are you a GMC Expert? Answer questions, earn points and help others
