Fuji FinePix F401 Digital Camera Logo
A
Anonymous Posted on Sep 24, 2013
Change language to english
For some reason it is in Turkish how do I change it to English
5 Related Answers
Anonymous
  • Posted on Oct 23, 2008
SOURCE: Want to Change Language
Dont purchase cameras with japanese language in future if they dont provide translation in english..
Anonymous
  • 423 Answers
  • Posted on May 22, 2009
SOURCE: camera is in japanese or chinese language and we need to change it to english.
go into the setup menu ("set") by pressing the menu button, and look for the picture of a little man yelling (he's speaking). That's the language set-up. Set it for english.
The self-timer is accessed through the arrow dial. The little picture of the clock at the bottom of the dial is the timer setting. The camera must be in the shooting mode to use the timer, not in playback. Here's a link to the owner's manual http://www.fujifilm.ca/x3717.xml
Anonymous
  • 223 Answers
  • Posted on Jun 01, 2009
SOURCE: language
Go to google translate and press the menu button on your camera. Type in language and translate into english. You should be able to highlight the proper sub menu to change the setting from there.
Anonymous
  • Posted on Jun 27, 2009
SOURCE: request for the english langage
Hello sir i have fujifilm finepix 4500 digital camera how i can english in english language
  • 102366 Answers
  • Posted on Mar 18, 2010
SOURCE: my finepix A800 is in japanese. I need it in english
Press MENU/OK to open the menu. Use the up/down-arrows to navigate to Setup (it should be the last item, marked SET) and press right-arrow. Use the right/left arrows to select Setup2 (the wrench with the digit 2) and press down-arrow. Use the up/down arrows to navigate to an entry marked with LANG and press right-arrow. Select "English" and press MENU/OK to confirm.
Testimonial: "the instructions were easy to follow and i was helped so well. A big thank you "
2helpful
How do I change language from chinese to english
MY PHONE LANGUAGE IS TURKISH I NEED CHANGE THAT TO ENGLISH
I have a Samsung sync master 943 bwx and when i first set it up my main menus was in some other language how do i get it back to english?
I have tried to find a manual, to see if there is a way to change it, but have not been sucessful.
The languages it supports are: French , Spanish , English , Swedish , Turkish , Italian , Portuguese , Russian , German so it's possible to use google translate to find out which is the option for language.
I know Spanish is Idioma, Swedish is
eitherS PR?K or TUNGOM?, Turkish is dil.
See if you can find that option, and you will probably find "English" or "Ingles" as a sub-option.
7helpful
3answers
How can I change the language on my Nokia 1616 from Turkish to English
Go to Settings (wrench icon) > Phone Settings > Language > Select Automatic or English
1helpful
2answers
Vista 32 bit Operating system is in Turkish.But I want int .Exp.8 in English ..please help
You can try changing the locale. This is in Control Panel->Region and Language->Administrative->Change System Locale. You can also install/uninstall languages from the language tab.
Hope this helps
Ray
My HP PSC 1315V changed its language to Turkish - how do I switch it back to English??
hello,
you can try going to this website and it will give you the English drivers for it. but you need to uninstall the current driver in Turkish and install the English one from the link "http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?lc=en&dlc=en&cc=us&product=374575&"
cheers
How can i can change MS Office 2003 language from Turkish to English ?
Go to Control Panel Click on Regional & Language options. On the drop down box Click on the format Tab and then select English Language. Click OK
3helpful
Urgunt Question hello dear friend I bought a HP netbook with model of compaq CQ10 mini from Turkey. When I turned on the netbook for the first time it's set up for preparing windows was in Turkish &...
Of course,no matter what the language of the windows is ,use your basic computer operation knowledge,you can change the OS Language in the Regional & Language option at Windows for your HP Mini 1000 Netbook PC Notebook.And it is showed in English for the word "English" .
How ichange the launage frm turkish back to english wat icon is it
Go to settings--then go to phone settings--then go to language settings--then go to phone language
there you can change your phone's language to english if this is not possible contact your phone's website there you will find latest details.
use google translater to get the turkish words for the bolded words.It could be easy for you to indentify the icons.
Thank you
3helpful
How can I change the language on my laptop?
If you just want to change the keyboard and general language settings, you simply go to the Start Menu -> Control Panel -> Regional/Language settings and change your language.
If your friend installed the Turkish version of WinXP (i.E. all the alert boxes are in Turkish) and you want to modify it to another language - that's a totally different and more complex situation.
In order to change the whole system language you can install a newer service pack in a different Language or uninstall the last installed Service Pack and after changing the registry settings below Install it again.
!!!Make always a backup of your Registry first !
You have XP SP2 in Turkish and want to change your systmes language to English, you will have to download SP3 in English (link).
(You can change the language here to another one before the download.)
Then you will have to change some registry keys. (Go to HKEY_LOCAL_MACHINESYSTEMControlSet001ControlNlsLanguage Registry Key), and change the value for “Default” and “InstallLanguage” from 041F (Turkish) to 0409 (English).
Reboot and you'll be able to install SP3 in English.
If no problems occur, you will have the whole system language changed.
Here is the List of numbers that represents each language in the registry:
* 0436 = "af;Afrikaans"
* 041C = "sq;Albanian"
* 0001 = "ar;Arabic"
* 0401 = "ar-sa;Arabic (Saudi Arabia)"
* 0801 = "ar-iq;Arabic (Iraq)"
* 0C01 = "ar-eg;Arabic (Egypt)"
* 1001 = "ar-ly;Arabic (Libya)"
* 1401 = "ar-dz;Arabic (Algeria)"
* 1801 = "ar-ma;Arabic (Morocco)"
* 1C01 = "ar-tn;Arabic (Tunisia)"
* 2001 = "ar-om;Arabic (Oman)"
* 2401 = "ar-ye;Arabic (Yemen)"
* 2801 = "ar-sy;Arabic (Syria)"
* 2C01 = "ar-jo;Arabic (Jordan)"
* 3001 = "ar-lb;Arabic (Lebanon)"
* 3401 = "ar-kw;Arabic (Kuwait)"
* 3801 = "ar-ae;Arabic (you.A.E.)"
* 3C01 = "ar-bh;Arabic (Bahrain)"
* 4001 = "ar-qa;Arabic (Qatar)"
* 042D = "eu;Basque"
* 0402 = "bg;Bulgarian"
* 0423 = "be;Belarusian"
* 0403 = "ca;Catalan"
* 0004 = "zh;Chinese"
* 0404 = "zh-tw;Chinese (Taiwan)"
* 0804 = "zh-cn;Chinese (China)"
* 0C04 = "zh-hk;Chinese (Hong Kong SAR)"
* 1004 = "zh-sg;Chinese (Singapore)"
* 041A = "hr;Croatian"
* 0405 = "cs;Czech"
* 0406 = "the;Danish"
* 0413 = "nl;Dutch (Netherlands)"
* 0813 = "nl-be;Dutch (Belgium)"
* 0009 = "en;English"
* 0409 = "en-us;English (United States)"
* 0809 = "en-gb;English (United Kingdom)"
* 0C09 = "en-au;English (Australia)"
* 1009 = "en-ca;English (Canada)"
* 1409 = "en-nz;English (New Zealand)"
* 1809 = "en-ie;English (Ireland)"
* 1C09 = "en-za;English (South Africa)"
* 2009 = "en-jm;English (Jamaica)"
* 2809 = "en-bz;English (Belize)"
* 2C09 = "en-tt;English (Trinidad)"
* 0425 = "et;Estonian"
* 0438 = "fo;Faeroese"
* 0429 = "fa;Farsi"
* 040B = "fi;Finnish"
* 040C = "fr;French (France)"
* 080C = "fr-be;French (Belgium)"
* 0C0C = "fr-ca;French (Canada)"
* 100C = "fr-ch;French (Switzerland)"
* 140C = "fr-lu;French (Luxembourg)"
* 043C = "gd;Gaelic"
* 0407 = "de;German (Germany)"
* 0807 = "de-ch;German (Switzerland)"
* 0C07 = "de-at;German (Austria)"
* 1007 = "de-lu;German (Luxembourg)"
* 1407 = "de-li;German (Liechtenstein)"
* 0408 = "el;Greek"
* 040D = "he;Hebrew"
* 0439 = "hi;Hindi"
* 040E = "hu;Hungarian"
* 040F = "is;Icelandic"
* 0421 = "in;Indonesian"
* 0410 = "it;Italian (Italy)"
* 0810 = "it-ch;Italian (Switzerland)"
* 0411 = "ja;Japanese"
* 0412 = "ko;Korean"
* 0426 = "lv;Latvian"
* 0427 = "lt;Lithuanian"
* 042F = "mk;FYRO Macedonian"
* 043E = "ms;Malay (Malaysia)"
* 043A = "mt;Maltese" 0414 = "no;Norwegian (Bokmal)"
* 0814 = "no;Norwegian (Nynorsk)"
* 0415 = "pl;Polish"
* 0416 = "pt-br;Portuguese (Brazil)"
* 0816 = "pt;Portuguese (Portugal)"
* 0417 = "rm;Rhaeto-Romanic"
* 0418 = "ro;Romanian"
* 0818 = "ro-mo;Romanian (Moldova)"
* 0419 = "ru;Russian"
* 0819 = "ru-mo;Russian (Moldova)"
* 0C1A = "sr;Serbian (Cyrillic)"
* 081A = "sr;Serbian (Latin)"
* 041B = "sk;Slovak"
* 0424 = "sl;Slovenian"
* 042E = "sb;Sorbian"
* 040A = "es;Spanish (Traditional Sort)"
* 080A = "es-mx;Spanish (Mexico)"
* 0C0A = "es;Spanish (International Sort)"
* 100A = "es-gt;Spanish (Guatemala)"
* 140A = "es-cr;Spanish (Costa Rica)"
* 180A = "es-pa;Spanish (Panama)"
* 1C0A = "es-do;Spanish (Dominican Republic)"
* 200A = "es-ve;Spanish (Venezuela)"
* 240A = "es-co;Spanish (Colombia)"
* 280A = "es-pe;Spanish (Peru)"
* 2C0A = "es-ar;Spanish (Argentina)"
* 300A = "es-ec;Spanish (Ecuador)"
* 340A = "es-cl;Spanish (Chile)"
* 380A = "es-uy;Spanish (Uruguay)"
* 3C0A = "es-py;Spanish (Paraguay)"
* 400A = "es-bo;Spanish (Bolivia)"
* 440A = "es-sv;Spanish (El Salvador)"
* 480A = "es-hn;Spanish (Honduras)"
* 4C0A = "es-ni;Spanish (Nicaragua)"
* 500A = "es-pr;Spanish (Puerto Rico)"
* 0430 = "sx;Sutu"
* 041D = "sv;Swedish"
* 081D = "sv-fi;Swedish (Finland)"
* 041E = "th;Thai"
* 0431 = "ts;Tsonga"
* 0432 = "tn;Tswana"
* 041F = "tr;Turkish"
* 0422 = "uk;Ukrainian"
* 0420 = "your;Urdu"
* 042A = "vi;Vietnamese"
* 0434 = "xh;Xhosa"
* 043D = "ji;Yiddish"
* 0435 = "zu;Zulu"
Top Fuji Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Fuji Camera Expert? Answer questions, earn points and help others
