KitchenAid KHMS155L Microwave Oven Logo
A
Anonymous Posted on Sep 24, 2013
Khms155lss4 khms155lss3 exploded - KitchenAid KHMS155L Microwave Oven
Error code F2
Per the tech sheets (page 8), "F2" error code means "Keyboard failure". Recommended by the manufacturer to replace the touch panel first and, if it would not solve the problem, then the control board has to be replaced too. Not the best recommendation but we have to follow it.
- The part number for the touch panel (aka a membrane switch) is AP3130765
- The part number for the control board AP3130764
Here are the break down diagrams for the Kitchen Aid microwave Model KHMS155LSS4
Gene.
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
Read more: http://forum.appliancepartspros.com/microwave-repair/19054-kitchen-aid-microwave-error-code-f2.html#ixzz3bRus7JKM
Kitchenaid khms155lss4 microwave combo went dead what fuse should i check frist
Check to make sure you are getting power to the receptical, plug a lamp to confirm. Next unplug microwave oven and remove top, "several screws" now look inside where the keypad is, follow the wiring to the circuit board, there should be a small glass or ceramic fuse clipped in, before you take it out discharge silver rectangular capacitor with a screwdriver across the points to make sure all voltage is removed. Now unclip the fuse and test, if open replace with the same current rating, if no change I recommend a technician to take it further. Please remember there is extreme high voltage when unit is plugged in and running making it lethal, put the top back on for safety sake.
Replace door handle, kitchen aid microwave, model KHMS155LSS3
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the screws you need to remove.
Or you can watch a YouTube video (not a video I made) here that demonstrates how it's done.
You can find handy exploded views and order parts by model number here.
I need to change the handle on my microwave modle khms155lss3. How do I get to the screws to take it off?
Microwave starts beeping and then locks up. We unplug and when we plug back in works and then when done cooking starts beeping and locks up. The last time I used today I did not reset the clock and it has...
You have a shorting membrane keypad.
NOTE: If and when an oven is coming on or doing anything by itself, this is very dangerous and can result in a fire.
So until it is repaired, please leave it unplugged or at least leave the door open when it's not in use, and of course one should never leave a microwave unattended while cooking.
On this model (
KHMS155LSS3), the membrane keypad comes on the complete control panel frame assembly.
In this case, you simply move your circuit board into the new frame. That is a simple do-it-yourself job.
It is part number 8205018 and you can get it from the Pros here for $108.80.
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Then you unplug the keypad (as per the photo below) and move the circuit board into your frame.
Some connectors on the relays may have a lock:
Keeps beeping shows F2
F2 means you have a shorted membrane keypad.
So until it is repaired, please leave it unplugged or leave the door open when it's not in use, and of course one should never leave a microwave unattended while cooking.
On these models, the membrane keypad is not available separately, so you'd have to order and replace the control panel frame, which comes with a new keypad already installed.
This is a simple do it yourself job.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
Your actual model number from the tag weill be one of these: KHMS155LSS0 KHMS155LSS1 KHMS155LSS2 KHMS155LSS3 KHMS155LSS4
3helpful
Kitchenaid microwave model KHMS155L, starts randomly for 3 minutes with "PAN" flashing on display screen, than locks up with "F-2" message on display screen
"F2" means you have a shorting membrane keypad. The "Pan Heat" key is shorting.
On these models, the membrane keypad is not available as a separate part, so you would have to order the control panel frame assembly which comes with a new keypad.
You can find helpful exploded view diagrams and order parts by entering your full model number* from the tag on the oven here.
Some connectors may have a lock:
* The exact part number you need will depend on your exact model number. Models in that series are shown below:
KHMS155LBL0
KHMS155LBL1
KHMS155LBL2
KHMS155LBL3
KHMS155LBT0
KHMS155LBT1
KHMS155LBT2
KHMS155LBT3
KHMS155LSS0
KHMS155LSS1
KHMS155LSS2
KHMS155LSS3
KHMS155LSS4
KHMS155LWH0
KHMS155LWH1
KHMS155LWH2
KHMS155LWH3
5helpful
Kitchenaide KHMS155LSS Microwave F2 apears on screen
"F2" means your membrane keypad is shorting.
So until it is repaired, please leave it unplugged or leave the door open when it's not in use, and of course, never leave an oven cooking unattended.
You can order the control panel frame assembly with a keypad already installed here .
You can also find handy exploded views there. Just do a search by full your model number (KHMS155LSS1, KHMS155LSS2, KHMS155LSS3, KHMS155LSS4, etc.).
You first unplug the oven and remove your control panel assembly as per the video at our site.
Then disconnect the keypad strip as per the picture below.
Then you take out the screws holding your circuit board to the old frame and put it in your new frame
Be careful, since the display is glass.
Reassembly is the reverse of disassembly.
Top KitchenAid Microwave Ovens Experts
ZJ Limited
ZJ Limited
john h
Are you a KitchenAid Microwave Oven Expert? Answer questions, earn points and help others
