How do I get sound to the second speaker zone?
The 5007 has 7 amp channels, so you can set up your main zone to be 5.1 channels and zone 2 to be the remaining 2 channels. Check the manual to see which speaker terminals on the back are connected to which speakers. You will need to go into the setup menu and set the amp for 5.1 + 2 channels. Then you will need to run speaker wires to Zone 2.
I recommend using banana plugs to connect the speaker wires to the 5007. They make a much neater install and eliminate shorts between connections. Sewell Direct makes nice plugs for a very reasonable price.
