If is a parametric equalizer is zero watts. ,pionner should have a front, rear and subwoofer connections. If i remenber correctly, a single rca going to your stereo and the rest from eq to amp or amps. Hope this helps ,hope you get WIRED.
check in yhe back of your amp to see if you have a pre amp power amp rca jumpers. If you do. remove these jumpers and take the pre amp out and plug it into the eq in. Then take the eq out and plug it into the power amp in. this will put your eq inbetween the pre amp and power amp. If you don't have these rca jumpers on the back of your amp, you can do the same with your tape record in and out inputs on back of amp.
top left - orange.....goes to aux or memory wire top right - blue.......goes to the remote wire used with amps bottom left - black.......goes to the ground wire bottom right - red........this goes to your hot wire
