SOURCE: Makes a rasping or grating sound whilst spinning.
one of your drum wheels apear to be making noise, they do use barrens try alittle inside see if it helps, plus one wheel could be bad dont use too mutch plus check your belt for wear and drum...
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
