SOURCE: Pegasus Push Button Vessel Sink Drain with overflow
Put plumbers putty around the flange that will be in contact with the sink. When you put it into the hole, try to line up the overflow as good as possible. The nut that goes onto the bottom (tailpiece) has a rubber gasket that will go between the nut & the sink. Adding some plumbers putty here won't hurt. After all is secure, just remove the putty that squeezed out from tightening.
