Epson Stylus C86 InkJet Printer Logo
What is a rpc server error? - Epson Stylus C86 InkJet Printer
Cant install driver with "rpc server is unavailable" and also shows both the se and se sec family in device manager.
INFORMATION SOURCE CREDITS TO >>
http://ezinearticles.com/?How-to-Fix-RPC-Error-When-the-RPC-Server-is-Unavailable&id=3298701
Have you gotten an RPC error lately? They look a little like this:
- "RPC Server is Unavailable"
- OR "The RPC Server is too busy to complete the task"
- Here's the best one, "Access denied"
This is fun stuff. Unfortunately, an RPC error is one of the most common errors out there, and most of us don't even know what RPC is.
What is RPC?
RPC stands for "Remote Procedure Call." This probably still doesn't tell you much. Let's see if we can put this in non-technical language. RPC is the go between of your computer and server. This is what allows your computer to access a network.
RPC has two main parts to it: the client and the server. When the client (the program requesting something) sends a message to the server (the process that takes the order or performs the task), it is being asked to execute a certain procedure. The client waits for the server to process the call before resuming the execution.
Why Won't the RPC Server Work?
Usually, the RPC error pops up because there is some sort of miscommunication between the computer and the server. Most of the time, the wires get crossed somewhere due to Internet components that are not configured or activated. Sometimes it is just a matter of adjusting the Internet Firewalls or Proxy Server.
Quick RPC Error Fix
One way to investigate an RPC server error is to verify that you have enabled the DCOM Tunneling is enabled and not being blocked by any third party Internet Security programs such as AVG, Norton, McAfee, etc.
To do this:
1. Go to Start and Run
2. Type in DCOMCNFG
3. Click on Component Services
4. Click on Computers
5. In Computers, right click My Computer
6. Choose Properties
7. Go the Default Properties tab
8. Check the "Enable DCOM" tab
9. Go to the Default Protocols tab
10. Click Add
11. By the Protocol Sequence move the down arrow to Tunneling TCP/IP
12. Click OK
13. Click MoveUp button until Tunneling is at the top of the list
14. Now you may select SPX and Remove
15. Click OK or close the program out
16. Restart the computer
When You Need Help with the RPC Error
The RPC Error is such a common error, it seems like it should be easy to fix. However, the DCOM Tunneling fix is only the beginning of troubleshooting an RPC server error. The good news is that you really don't have to do anything when it comes to an RPC error if you maintain your computer with registry maintenance tools. Try researching the benefits of a registry cleaner to fix RPC errors.
Optimize-Your-PC, with its Advanced Registry Cleaning Technology, will repair an RPC error, and Speed Up Your PC, all in under 2 Minutes.
ALSOP TRY DHCP CLIENT RESET
HI While installing Vedio driver is trowing RPC server unava
Hello sans_sankar,
If it says RPC server is unavailable, that has to do with your internet connection.
Check if both ends of your ethernet or USB cable are properly plugged in their ports on your modem or router to your computer.
You can also turn the modem or router off for a minute then turn it back on again.
Your video installation should be complete, otherwise, it might be incompatible with your computer.
Hope that helps.
Yours truly,
Art Pena
Printing Problem.
RPC server may not be started issue the following command to start the RPC server:
net start rpcss
I successfully ran the command to resolve a previous problem. keep me posted
1helpful
RPC ERROR! Avast anti-virus
RPC is a windows component, what you can try is uninstalling Avast then re-installing it.
13helpful
Rpc server is unavailable
The computer displays error "RPC Server is unavailable".
It may be that you have a static value in your registry's field PagedPoolSize, we need to make this "0" (zero). check the steps ->HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Session Manager\Memory Management
2answers
The RPC server is unavailable
Goto Run and type services.msc...and then there u have to restart the RPC service..
2answers
RPC Service not running
Please restart the service of RPC.
Write the script for RPC services by the help of google ur problem will be shortout .
Regards
MAYANK GUPTA
Top Epson Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
NH TECH
Level 1 Expert
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
