Loosen the screws with the help of tools
Here is the solution:
1) Close out any open applications and restart the computer.
2) As the machine boots up (at the eMachines logo), press F2 (to enter the BIOS).
3) Once you are in the BIOS, navigate (use the keyboard directional arrows) to the Exit Tab.
4) Under the Exit Tab, choose "Load Optimal Defaults". When you are asked to confirm, select "Y" (for "yes").
5) Save the changes and Exit the BIOS.
6) No more loud fan!! Awesome!
Disconnect the ground cable from the negative battery terminal, by using a wrench to loosen the retaining bolt and pulling the clamp off the terminal.
Raise the vehicle and support with jack stands placed underneath the frame.
Drain the transfer case. Locate the drain plug near the bottom of the transfer case. Place a waste oil collection pan underneath the plug and use a socket to remove it. Once all the fluid has drained out, reinstall the plug.
Remove the bolts that connect the rear driveshaft to the rear axle yoke using a socket. Lower the driveshaft, and slide it backward underneath the rear axle to disengage it from the transfer case. Remove it from the vehicle.
Remove the bolts that connect the front driveshaft to the front axle yoke using a socket. Lower the driveshaft, and slide it forward underneath the front axle to disengage it from the transfer case. Remove the driveshaft from the vehicle.
Label and disconnect the electrical wires and vacuum lines connected to the transfer case. Use masking tape and a marker.
Remove the transfer case shifter rod. Using needle-nose pliers, remove the clip that connects the shifter rod to the transfer case. Slide the rod away from the transfer case.
Position a floor jack underneath the transfer case. Raise it enough to take the weight of the transfer case off the transmission.
Remove the bolts that connect the transfer case to the transmission using a socket or wrench.
Slide the transfer case rearward to disengage it from the transfer case. Lower the floor jack, and remove the transfer case from the vehicle.
