RCA M4204  MP3 Player Logo
raharimanana kristifor Posted on Sep 24, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Doesn't start - RCA M4204 MP3 Player
Unknown Person
Level 2:
Sergeant:
  • Expert 245 Answers
  • Posted on Sep 24, 2013
Unknown Person
Expert
Level 2:
Sergeant:
Answers
245
Questions
0
Helped
46932
Points
662
  • Battery may be depleted. Please recharge.
  • Ensure the keys lock is not activated.
  • Reset the player by pressing and holding Power/Menu for more than 10 seconds.
  • If the player still cannot be turned on after resetting, perform a firmware upgrade to restore it.
Start up
You provided no info on the vehicle motor,so
I would assume you may have an Air Idle Solenoid
next to the throttle or on the intake manifold,that you
can remove & try cleaning or replace.
2000 elantra white smoke during speed, doesn't start
White smoke normally indicates steam, did the car overheat ????...if it overheated check hoses for leaks,,,, loss of water etc
2004 Ford Taurus won't start?
get your battery checked
Mk4 gti vr6 has power but doesn't start, runs with pop start
Could be a number of things but may want to begin by checking wiring to starter, battery, or even the ignition switch. These components may not turn your engine light on.
2answers
1994 Toyota Camry doesn't start without shaking
sounds like it having trouble starting. when was the last tune up ,and are there any codes on.
Dodge caravan 1996 doesnt start
It is very hard to help you when you give no details. But if it doesn't do anything when you try to start it you probably need to charge battery or get new one. If it is trying to start and doesn't sound weak then you need to have someone look at it. It doesn't sound like you would want to do anything yourself but if its not the battery, it doesn't sound good. Good luck
2helpful
Doesn't start has spark @ plug fuel @
try starting meaning pull the rope 6 times and then check the spark plug if its wet clean it or try a new plug, if its dry your not getting fuel in the cylinder which means carb problems. if you have a seringe or something to put some gas into the spark plug hole then install spark plug and try it. if it runs for a couple of seconds then you need to focus on the carb. only put a small amount of fuel in the plug hole if you try it otherwise youll be pulling on the rope for awhile before it will start. hope this helps.
Doesn´t start
Have you tried "Last known good configuration"?
Top RCA Audio Players & Recorders Experts
 Grubhead
Grubhead
Grand Canyon Tech
Grand Canyon Tech
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
