Canon ZR85 Mini DV Digital Camcorder Logo
Stacey Brown Posted on Sep 24, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Power battery DOES THE LIGHT FLASH WHEN POWERED OFF AND PUT OM THE CHARGER
Vuk B
Level 3:
Master:
  • Master 717 Answers
  • Posted on Sep 25, 2013
Vuk B
Master
Level 3:
Master:
Answers
717
Questions
0
Helped
284174
Points
1244
Is the unit charging but you cant see the light for charging or it's not charging at all?
Yellow and green light on ryobi charger
I think it's where the batteries get put on their charger and left on there and when you take them off the charger they are fried. Starts off by not holding charge long and then not charging. Two batteries did this to me. They are suppose have a cut off were it doesnt burn om up the batteries??? What happened?? Should be recalled!!!!
2answers
Red light in charger flash when battery is put in to charging
This behavior is typical of trying to charge a battery that is wither too hot (let it rest for a hour) or one that has done its job and is ready for the battery retirement home. Replace your battery for best results with your Ryobi battery powered tool.
How do i charge my camera so that i can explore
You can charge the battery in two ways.
Use the supplied battery charger. Remove the battery from the camera, put it into the charger, and plug the charger into a power outlet.
Connect the camera via a USB cord to a powered USB outlet. Be aware that not all computer USB ports put out enough current to charge the battery. You might want to consider a cell phone charger that plugs into a power outlet.
Dell Inspiron 1525 laptop, no power light, battery light flash orange, wifi light flash blue and orange I bought the Dell Inspiron 1525 laptop in 2008. I use the laptop as a desktop, so I never plugged...
Since it sounds like an issue with the Power first try to release flea power.Disconnect the charger,remove battery,press and hold down the power button for 30 seconds.Reconnect the battery and charger.Turn on system and check if it turns on. For further help please check Dell Inspiron 1525 Manual. Also confirm if the light on the charger stays on,when connected to the system.
Hi i have put power supply in anbd powered up my power supp;y shows green light but when i press power on butoon on my e1705 nothing happens no lights flash nothing totally dead
Hi
Please can you try the followinf
1) remove wall charger
2) Remove battery
3) Press and hold power button down for apporx 30 seconds
4) Plug in wall charger
5) Power on laptop
6) If successful plug in battery
Regards
Shauqat
Lumix dmc-fs5 digital camera not turning on without charger.
Some Panasonic cameras only work with Panasonic batteries...part of Panasonic's plan to dominate the world! Is your replacement battery an off-brand?
4helpful
3answers
When put on charge the green and red light flash
Yep, not the batteries, mine is doing the same thing but my second charger works fine with the same batteries
SAMSUNG SPH-a620/VGA1000 = Won't power on at all!
ya try wit another battery it will surely work ....................
Is my camera broke?
sounds like your battery or charger might be defective. I have this camera an when the battery is to low it flashes the screen.
I still use the original charger that came with it to charge the batteries,been thru 4 of those. It seems if they set a while without being charged the go bad.
Top Canon Video Cameras Experts
NOEL
NOEL
john h
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
