SunBriteTV 2300HD 23" TV Logo
A
Anonymous Posted on Sep 23, 2013
"remote control directv", sunbrite TV codes - SunBriteTV 2300HD 23" TV
I have a Toshiba 37" LCD Model 37E200U no code seems to work with my Direct TV Rc64R remote control any ideas ?
I can help you with your Toshiba TV & DirecTV remote control.
This is a list of all the Toshiba TV control codes for DIrecTV remote controls:
11524, 10154, 10156, 11256,
10060, 12006, 11945, 11936,
11935, 11918, 11704, 11656,
11635, 11369, 11356, 11343,
11325, 11306, 11156, 10845,
10832, 10822, 10650, 10149,
10148, 10036, & 11971.
There are so many codes to try for Toshiba and DirecTV, you might want to go ahead and do a DirecTV Remote Control Code Search.
I hope that helps.
_________________________________________
DirecTV Remote Control Code List Download
DirecTV Remote Control Manual Download
DirecTV Remote Control Code Entry
DirecTV Remote Control Onscreen Setup
tip
DirecTV Remote Control Code Search Tosearch for a control code for your TV...
Tosearch for a control code for your TV using your DirecTV Remote Control, follow these steps:
  1. Turn on the TV.
  2. Slide the MODE switch to the TV position.
  3. Press and hold the MUTE and SELECT keys at the same time until the green light under the TV position flashes twice, then release both keys.
  4. Enter 9-9-1 followed by 1:
  5. Aim the remote at your TV and press the PWR key once.
  6. Point the remote at the TV or component and press
    CHAN ^. Repeatedly press CHAN ^ until the TV turns off.
  7. When the TV turns off, press and release the SELECT key.
You have programmed your DirecTV remote control for your LCD TV.
on Jun 10, 2010 • Televison & Video
tip
DirecTV Remote Control Code Entry To enter a control code for your TV using...
To enter a control code for your TV using your DirecTV Remote Control, follow these steps:
  1. Turn on the TV.
  2. Locate the 5-digit code for your TV. (See DirecTV Remote Control Code List, page 14.)
  3. Slide the MODE switch to the TV position.
  4. Press and hold the MUTE and SELECT keys at the same time until the green light under the TV position flashes twice, then release both keys.
  5. Using the number keys enter the 5-digit code for your brand of TV. If performed correctly, the green light under TV flashed twice.
  6. Aim the remote at your TV and press the PWR key once. Your TV should turn off. If it does not turn off, repeat steps 4 and 5, trying each code for your brand until you find the correct code.
2helpful
Can not get the directv universal remote to work with my older
I can help you with your Sony TV & DirecTV remote control.
This is a list of all the Sony TV control codes for DIrecTV remote controls:
10000, 10810, 10010, 10011,
10080, 10111, 10834, 11317,
11685, 11904, 11925, & 10505.
There are so many codes to try for Sony TVs and DirecTV, you might want to go ahead and do a DirecTV Remote Control Code Search.
I hope that helps.
tip
  1. Turn on the TV.
tip
  1. Turn on the TV.
2helpful
Direct tv remote to visio tv
I can help you with your Vizio TV & DirecTV remote control.
This is a list of all the Vizio TV control codes for DIrecTV remote controls:
11758, 10864, 10885, 11499, & 11756.
Complete instructions on entering DirecTV remote control codes are here.
I hope that helps.
Akai lct2715 directv remote code
I can help you with your Akai LCD TV & DirecTV remote control.
This is a list of all the Akai LCD TV control codes for DIrecTV remote controls:
11675, 11676, 11688, 11689, 11692, 11693, & 11935.
I hope that helps.
I lost my remote and need to switch the tv so I can get Directv - how can I do this without my remote
To get your TV setup so that you can view your DirecTV on it, I recommend you program your DirecTV remote to control your TV and then use the DirecTV remote to change the input of your TV to view the DirecTV programming.
You can choose between searching for the control code and
entering a code from the Toshiba TV list.
10148, 10036, 11971
I hope that helps.
Top SunBriteTV Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
Are you a SunBriteTV Televison and Video Expert? Answer questions, earn points and help others
