SOURCE: how can i round off
Do you mean round off to the nearest thousandths? The thousandths place is the third place to the right of the decimal point. An example would be 0.001. In this case you have a 1 in the thousandths places which would be stated as one thousandth. To round to the nearest thousandths place you would look at the number in the ten-thousandths place and use that to determine what the number in the thousandths place should be. For example, if you have a number such as 0.1234 your answer, rounded to the nearest thousandth would be 0.123 because 4 is less than 5 and therefore you would round down. If you have a number such as 0.1235 your answer would be 0.124 because you always round up if the number in the next decimal place is 5 or higher.
I hope this helps.
90,000 to the nearest ten-thousand remains as it is that is: 90,000
