eMachines EL1333G-01w Logo
Mario Sanchez Posted on Sep 23, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
When I connect the Network cable the computer start to restart and continue and not stop.but when I disconnect the cable is work normally.
ranchhand
Level 2:
Sergeant:
  • Expert 242 Answers
  • Posted on Sep 24, 2013
ranchhand
Expert
Level 2:
Sergeant:
Answers
242
Questions
Helped
32758
Points
510
#1: Do a system repair; see the manual that came with your computer, it will explain how to do a repair restore without losing any programs or data. OR Google search system repair and add the make of your computer. Do not do a fresh/new install or you will lose everything.
#2: Delete and reinstall the network card drivers. You can usually find them on the motherboard driver CD that came with your computer. Usually the CD will first remove all drivers, then will reinstall them, but that depends on the manufacture of your computer and operating system.
tip
How to Troubleshooting Network
Here you will learn network troubleshooting tips, fix tcp/ip errors, tcp/ip settings, internet connectivity errors, how to fix pc errors, lan connectivity issues, traceroute and ping commands. Whether your operating system is Windows or Linux network problems are likely to arise. Many times the network problems arisee due to improperly configured TCP/IP settings. Following is the basic checklist to identify and troubleshoot the basic networking errors.
1. First of all you should learn what stopped working server or client computer also see if the outage affecting the other computers or only one.
2. If you server stopped working you should inform the users of the server and you should start working on fixing the error.
3. If a single client computer stopped working or disconnected from the network, ask the user of that computer that what recent changes cause the server to stop working such as newly installed software or games, service packs, internet software, new hardware or any other thing.
4. Check the physical network connectivity. The most network problems arise due to the physical layers failure.
5. Check all the network cable connections. You can start at the NIC and check if the green light is blinking then check the hub and see if the computer is getting the link across the cable.
6. Get a cable tester to check the connectivity of the cables.
7. Finally start pinging the network both Windows and Linux have the PING command. You can use ping command in this way start > Run > cmd > type "ping" then IP address of the other computer
on Mar 25, 2010 • Computers & Internet
I have a networked printer in my office. it has been working normally until recently where it takes no print command from any of the networked computers. If i disconnect the network cable, the test print...
Try this solution
Go to START MENU
Choose Commamd prompt, right click mouse and run as administrator ( For Window vista and windows 7)
Type the letter "cmd"
Type the word "net stop spooler"
Exit
Go to C: drive
Choose to Windows Folder
Click show content
Choose system32 folder
Choose spool folder
Choose printer
And delete all printing jobs pending
Again go back to CMD window and type the word "net start spooler"
Restart your computer and must also turn off your printer and then switch it on.
It will work fine right now
I hope it helps you
Please let me know it you need more help. Regards
2helpful
It worked fine last nite;came home today and it wont pull up the eweb or start or anything I click on? It said at one point I was not connected to any network;now it says am connected to Netgear network. I...
There are lots of possibilities here. The first thing is IF you are connected through a wireless network, Disconnect from the network. If you are networked directly into the Comcast modem, disconnect from the cable modem. If you disconnect from the network entirely and things seem to return to normal, then it is possible that you have a cable modem problem, a wireless router problem or someone has hacked into your network. The latter is most likely if you are running a wireless router and it is unsecured as this allows others to use your wireless network without your permission. If you disconnect from the network and things seem to improve only slightly, try running a virus scan while disconnected from the network and see what pops up. If anything has been downloaded to your computer a virus scan should find it. I would also recommend going in and making sure file sharing is turned off. If things seem okay after a virus scan, then try hooking back up to the network. If everything seems okay at that point, then most likely the cable modem or router are okay. If you still have a problem after reconnecting to the network try resetting the cable modem and the router. If you continue to have problems, I would call Comcast at that point and have them help you troubleshoot the cable modem to see if there is a problem with the modem.
D-Link DI-534 Starting up problems
Try resetting the router . Press the reset button for 10 seconds and after 10 seconds unplug the power cable but continue pressing the reset button for another 30 seconds after 30 seconds plug in back the power cable and continue pressing the reset button for 10 seconds and release it after 10 seconds.
try to open an Internet browser and type in 192.168.0.1 on the address bar. It should give you the DLink page. Once you have that configure your connection.
Printer Won't Print
Step one: Restart the computer
Click Start and click Shut Down.
Click Restart or select Restart from the menu. Click OK.
After the computer restarts, double-click the Printer icon in the system tray located at the bottom, right of the computer. The print queue opens. If no documents appear in the print queue, the issue is resolved.
If the issue continues, proceed to the next step.
Step two: Check the product cable, Disconnect the USB cable from the product and from the computer.
Wait 5 to 6 seconds. Reconnect the USB cable to the product and computer.
(NOTE: The product must be connected directly to the computer using a USB cable or a powered USB hub. If the product is connected to the computer through a non-powered USB hub, or if the type of hub is unknown, connect the product directly to the computer) after the product is connected to the computer, the product should start printing the jobs in the print queue. If the issue continues, proceed to the next step.
Step three: Determine whether the product is paused or offline, Click Start and click Printers and Faxes. The Printers and Faxes window appears. In the Printers and Faxes window, right-click the product icon and click Open. The Printers folder opens. On the menu bar, click Printer. Make sure that the Pause Printing and Use Printer Offline options are not selected. If a check mark appears next to either option, click to remove it. If the menu includes Use Printer Online, click that option.
If neither Pause Printing nor Use Printer Offline is selected, press Esc to leave the menu without making changes.
Step four: Stop the print queue, Double-click Macintosh HD, Double-click the Application/Utilities folder.
Open the Print Setup Utility folder; Double-click the appropriate product in the product list to open the print queue.
Click Start Jobs. (NOTE: If the queue was accidentally stopped, the print job will resume automatically. If the issue continues, proceed to the next step)
Step five: Delete the print jobs, Double-click Macintosh HD, Double-click the Application/Utilities folder.
Open the Print Setup Utility folder, Click a print job and click the Delete icon. Repeat the steps for all the jobs in the print queue, Click Start Jobs, Double-click the appropriate product in the product list to open the print queue.
When the print queue is empty, click Start Jobs. Try the print job again. If the issue continues, proceed to the next step.
Step six: Remove and re-add the product to the printer list, Double-click Macintosh HD, Double-click the Application/Utilities folder, Open the Print Setup Utility folder, Select the appropriate product.
Click the red X to delete the product from the computer, Disconnect the USB or Ethernet cable from the product.
Close all open windows and restart the computer, after the computer is restarted, double-click Macintosh HD.
Double-click the Application/Utilities folder, Open the Print Setup Utility folder, and Reconnect the USB or Ethernet cable to the product. If the product is not automatically added, click Add. Select the product to add and click the Add button. After a few seconds, the product appears in the printer list. Try the print job again.
Scanner comes on automatically at computer startup
I would suspect that you have something else attached to your computer that is causing the scanner to react.
Disconnect the USB cable from the scanner and restart the computer. After the computer has fully restarted, connect the USB cable to the scanner. The scanner may initialize at this point. If after 30 seconds the scanner continues to cycle as you described, the that is an indication that there is something that is actively pinging the USB ports causing the scanner to react. If the scanner doesn't continue cycling, then reboot the computer and see if it does it again upon bootup.
Assuming that the scanner continues recycling:
Disconnect all USB devices (except the scanner) from the computer and then restart. If the problem goes away, then one of those devices is the culprit. Connect them one at a time, rebooting each time, to determine which devices is causing the problem. Once you determine the cause, then you'll know where to go for help.
Hope this helps.
Top eMachines Computers & Internet Experts
Andrew Chrostek
Andrew Chrostek
Level 1 Expert
Are you an eMachines Computer and Internet Expert? Answer questions, earn points and help others
