I inadvertantly kept using the calculator when the paper ran out. Consequently the paper became jammed in the machine. With much diffulty, picking with a fine instrument,etc. we finally released the stuck paper. We put a new roll in the maching. It initially worked for about 6 inches work of paper. Now it won't moved.
Please confirm that nothing droped inside in your printer (pins-stapler-small pieces of torn paper)-double a piece of paper roll and try to insert it while you press paper feed button to remove any object in paper path- apply light grease in gears and test your calculator.if the problem exist pass it to service center.
had paper jams and cleared them out after a little manipulation, however, now when I go to put the paper in the machine, the paper will not advance
