Toshiba Portege M400 PPM40U01000E Tablet PC Logo
Harry Smith Posted on Sep 23, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Flashing orange light when polugged in tried taking battery out and plugging inbut doesn't work, i have recently rebuilt it due to getting it from friend on spares or repair, it was in bits on delivery but now i have rebuilt it and nothing works this is my last resort before swending it off
Unknown Person
Level 2:
Sergeant:
  • Expert 245 Answers
  • Posted on Sep 23, 2013
Unknown Person
Expert
Level 2:
Sergeant:
Answers
245
Questions
0
Helped
46891
Points
662
Use this service manual to solve the problem.
Testimonial: "i would prefer not having to pay for it come on"
1helpful
Kindle went dead, plug in charger, looks like a battery with an orange light appears. Can this happen?
I would say your battery is shot. Can you get it to some one with a tester to check it out.
tip
Kindle not charging
If your Kindle (any version) is not charging because the USB port has gotten loose, try this...wrap a small piece of aluminum foil around your USB connector - the end that plugs into the device. Be careful not to extend the foil past the end of the connector, you don't want to damage your device. Plug the cable in to the outlet and into the Kindle port as usual, then watch the orange light come on!
Kindle charging ports get worn out over time, the foil is a great conductor and makes a solid connection. Obviously, you'll want to try a different cable first, but if that doesn't work, this is free and easy!
on Mar 26, 2015 • Amazon Kindle Fire HD
2answers
2answers
After charging my lindle on my laptop i cant switch it on
Try charging it with the electrical wall plug-in.
I read in some Kindle reviews on Amazon that charging through USB ports on a computer doesn't always work.
Did you get a green light that indicated the battery was fully charged?
2answers
When turning n the cruz tablet, the word cruz pops up and goes away. then cruz flashes
First don't worry too much you're just stuck in a loop or have bad firmware (most likely). The fix is probably going to be easy but you have to do some things. Just follow the directions I give and that Velocity gives and you should have no problems in about half an hour.
Take out the top SD card. Put in in your computer or an adapter that goes to the computer.
Go to the cruz website and download the current firmware (http://cruzsupport.velocitymicro.com/ics/support/KBAnswer.asp?questionID=814).
Even if you have updated the ROM something could have happened and it could be corrupted so replace it. Put that firmware on your sd card. Do not extract the zip file. Do not change its name. If the name changed (like if it has (01) at the end) delete the old file you downloaded and change the new one back to the old name.
Eject your sd card when you finish and put it in your tablet.
Press the top power button and the up volume button at the same time. Continue holding. You will see cruz but dont stop.. it'll flash kinda and it'll still say cruz.. keep effin' holdin'...
the robot shows up: you win! let go relax give it some time to freshen up. Have a cup of coffee and let it finish. Everything will be tidy and new when it's done.
the robot doesn't show up and the same thing that's been happening happens again: try pressing reset when it turns on (paper clip in that hole youll feel a button when you get it right). Keep pressing it the whole time it has power to try and get a hard reset. Do it like 2 or 3 starts and fails just for good measure.
then try to flash again (power and volume up).
if that doesn't work pull the back, unplug the battery and wait 30 seconds to a minute. plug it back in and try flashing the first time you start up. like don't press power hoping its going to turn on now. It won't. You have given it a clear quick access memory which may let you get to the point where you can flash without failing.
IMPORTANT: On the first time after the battery is plugged in hold power and up volume together and keep holding. This is important. If you press power it will recurrupt the RAM and you made the back lose and unplugged the battery for nothing.
If that doesn't work.. well it should. You're stuck in a loop that you should be able to pull out of. Go back the the beginning and make sure you have the new file you downloaded and the name is correct (its on the cruz support website).
If that's all done properly try the battery thing one more time. If it's still failing don't give up.. give it hell. I was stuck in a bad one going strait to white screen only being able to shut it off by pulling the battery and I was able to get it to flash (took about 30 tries). For the trying at this point you don't have to pull the battery just keep starting it with power and volume up pressed.
As long as you're not staring at a black screen you should be able to fix this.
Good-luck!
Motion Computing C5 Tablet PC won't power on
Hi! I do understand that you are having the problem on the laptop turning on. Try another option, turn off laptop, remove cables and battery, press and hold power button for 10 secs. Reinsert the cables and battery on the laptop. Then turn it on. If the laptop did not turned on, remove the power cable and turned on the laptop. If still didn't, remove the battery and insert the power cable. If still did not work then check if there lights flashed on the laptop when turning it on. If still does not, then you need to contact the pc manufacturer for repair and possible replacement. Otherwise, if there is light on the laptop, then there might be a problem either the battery or the power cable itself. If there is light on the laptop but no power cable, most likely the monitor did not work simply because the battery works due to the fact that there is light on the laptop. On the other hand if there is light when plugging in the power cable on the laptop, then you need to check and insert another battery if it works. Otherwise you need to replace the battery...
3answers
My m400 wont start at all, just an orange light blinks at the power light
have you had any power surges lately?
Try taking the battery out of the laptop and starting just on power.
if this doesnt help then take battery and power and leave laptop for few hours then try again on only power or battery.
Let us know how it goes.
1helpful
Acer Travelmate C112TCi- Won't power on
Remove the adapter and the battery from the laptop.
Press the power button and hold it down for 20 seconds(without the battery or adapter plugged in to it). This process is called POWER DRAIN.
Now connect only the adapter and try to turn it on.
If it starts up, there is no problem with the adapter or the laptop.
If it doesn't, it can be either the adapter or the laptop.
You will have to check it with a different adapter to confirm which one is faulty.
The second case is that the computer powers on only with the adapter.
Then you can put the battery back in and try powering it up.
If it doesn't work, try connecting the adapter too.
If still it doesn't work, its a faulty battery.
Sometimes after doing a power drain, the computer will work fine.
If you have any more issues, feel free to contact me.
Top Toshiba Tablets & eReaders Experts
k24674
ExpressFiX
ExpressFiX
Grand Canyon Tech
Grand Canyon Tech
Are you a Toshiba Tablet and eReader Expert? Answer questions, earn points and help others
