Hi My pendrive is write protwcted, Pendrive is CORDIAL4GB I ball plz give me a solution
Some pen drives have a small toggle switch with them which make the drive write protected try locating that switch. If there is no such switch then try formatting the drive preferably from safe mode. you can do this by following these steps:
1. Shutdown your computer or laptop
2. Insert USB Memory Stick into your laptop or Computer
3. Turn on laptop and then immediately start pressing (F key then Advanced Boot Options screen will come up
4. Select Safe Mode with Command Prompt
5. After loading files if your USB Memory Stick drive letter is (G) for example then write as
6. C:\windows\system32>G: and press enter
7. G:\>format G: and press enter
8. If ask you (Y/N) then press (Y) and press enter
9. Now a full format will start which remove write protection from USB Memory Stick.
