Bobbin thread breaks at bobbin. Tension is set correctly. Bobbin case and surrounding set up sounds like it may be slipping. It clicks while sewing.
pls, the see the figure how bobbibs thread directionhave you seen theres a screw on latch body case of bobins,you can adjust this but mostly this is factory
adjusted,bobbin tension can adjust here.but try to follow the thread direction.set up again the dial setup tension to #3 and stitch to #8 to #12.bobbins slip due to accumulation of thread under
bobbins.hopefully this may help you to continue sewing.
have a nice day,
