Dell HK395 Computer Speakers Logo
A
Anonymous Posted on Sep 22, 2013
Can a Harmon Kardon HK395 Dell 7E840 sub woofer work stand alone
1 Related Answer
Anonymous
  • 7 Answers
  • Posted on Jul 05, 2009
SOURCE: only have the sub will it work with out the small
no:(
Quiero conectar el hk395 se que sirve y me gustar?a mucho que me ayuden por favor
WHO TO connect hk395 sub woofer amp. hk395
I used google for you, so can you. 1st hit.
Harman kardon
http://www.fixya.com/support/t13715992-hk395_subwoofer_pinout_diagram
https://fccid.io/E2XHK395/User-Manual/users-manual-147573.pdf
its only 1 of 3 parts , Bottom left 2nd inward.
1helpful
The left speaker sometimes stops working. If I giggle the off/on switch on the right speaker it comes back on. What can I do to fix the problem?
you could try cleaning the switch.
could be just bad connections.
or just replace the switch.
or a loose connection.
it could be none of the above but worth checking.
What cable connects a Dell PC to a Harmon Kardon HK395 sub woofer?
3.5 m/m. Normally it is color coded green. The pink connects the subwoofer to the speakers. Any color will work. Just mark both ends of wire jacks.
1helpful
1helpful
How to connect the subwoofer to my Tv Samsung???
Most of the time there is a foldback of the left and right audio inputs of the subwoofer in that they use and sum the L and R audio and then filter the high end off. That means that the audio outs from your source be it the TV audio outs or a AV receiver that they can be Y corded to the sub woofer for that purpose.
Question on allowable use
Hi sheawm. You can use your speakers as long they have the mini-plug connector such as ipods, blackberrys, laptops, desktops, etc. so it won´t matter. I hope this helps.
Harmon Kardon SoundSticks II sub-woofer cleaning
These "proposed solutions" obviously have absolutely NO relation to the problem stated. Which by the way is far too typical of this site. :(
Top Dell Audio Players & Recorders Experts
SmartAviator
SmartAviator
ADMIN Andrew
ADMIN Andrew
 Grubhead
Grubhead
Are you a Dell Audio Player and Recorder Expert? Answer questions, earn points and help others
