Question about Black & Decker Drills
My 18 volt battery charger part number 5100235-06 has a resistor number 2 discolored cant make value out please help me as i wish to replace it
5 Suggested Answers
rowdy45176
David Ford
  • 2176 Answers
SOURCE: 18 volt ryobi battery charger...green & yellow lights come on wha
talked to Ryobi and they are vague. It can either mean that the battery is bad, or the charger is bad and another one that maybe the contacts of the battery are dirty or not seating fully in charger. What I would look for in this instance first unplug the charger and look into charging slot to make sure the terminals of the charger are not bent and they come out into the cavity where battery would go. If not gently pull terminal into opening and retry. Sorry I couldn't be of more assistance
Posted on Dec 31, 2008
frankzen
frankzen
  • 19 Answers
SOURCE: Jobmate 18 volt chordless drill charging
About 60 minutes...max 90 minutes. Do NOT leave it on the charger for hours and hours...that just cooks the battery.
And switch regularly between the two batteries...else the one that doesn't get used will die.
Posted on Apr 04, 2009
Anonymous
  • 4 Answers
SOURCE: delta 18 volt charger broken
buy a new one
Posted on Oct 06, 2009
Testimonial: "you missed the point te charger is "obsolete""
odelle_17063
  • 115 Answers
SOURCE: I have burnt out one of the resistors in my 18
MOST OF THE TIME MANUFACTURERS DOESNT SELLE DIAGRAMS,BECOZ THE WANT ONLY TO REPAIR THEIR PRODUCT BY THEIR CERTIFIED TECHNICIANS.
Posted on Oct 22, 2009
Anonymous
  • 8 Answers
SOURCE: charger not charging have 2 new chargers neither 1
You should probably contact Customer Service regarding this. I'd say it's a problem with the batteries rather than the chargers considering this looks like a recent EPC model - 1800 444 224
Posted on Nov 17, 2009
Burnt resistor on Lincoln 1210 battery charger base
Dear Anon,
A R5 Resistor Might Be 1K ohm.
Sep 15, 2014 | 1210 110 Volt Charger
Charger schematics
WASHINGTON, D.C. - Consumers should stop using this product unless otherwise instructed.
It is illegal to resell or attempt to resell a recalled consumer product.
Recall Summary
Name of Product: Ryobi P113 Dual Chemistry Battery Chargers
Remedy: Replace
Consumer Contact: One World Technologies toll-free at (800) 597-9624 from 8 a.m. to 5 p.m.
ET Monday through Friday or online at www.ryobitools.com and click on Important Safety
Information at the bottom of the page for more information
http://www.ryobitools.com/news_item/Final_CPSC_Approved_Press_Release_11.5.13.pdf
Aug 22, 2012 | Ryobi P113 18 Volt One Charger 140501001
Will a ryobi 18 volt charger replace a coleman powermate battery charger?What's your problem?
They look different in their shape where the battery goes so I would say no. To be safe always use the charger from the same manufacturer. There are a few different types of batteries too so it is always best to use the model number of your original charger to search for the replacement.
Aug 08, 2012 | Coleman Cable Coleman 18 Volt Combo Drill...
Ryobi 18 volt battery charger
If replacing the charger is not an option, open it up and check the fuse. Another item to check is the current limiting resistor, color coded red-red-black.
Feb 16, 2012 | Ryobi Drills
I have a B&D Firestorm 18v 1-hour battery charger, model 5100235-09 (240v). When I insert a battery to charge, only the green "battery full" LED lights immediately. But the battery never...
Hi I have same problem with the charger. Solution is to replace the charge with new part number issued from B&D Australia
Number of 90515050-01 until stock runs out , then it is replaced by part number of 90578873 early to mid june 2013.
Hope this helps
Lance from Perth , Western Australia.
Jun 19, 2011 | Black & Decker Drills
I have 110 volt durapro 18volt dc battery charger, component R14 has burnt out beyond recognition and I was hoping someone could tell me exactly what it is so I can replace it. Thanks
The component is a resistor. The problem is going to be determining the resistors value since it was burnt and you can not see the color code. You might try contacting the manufacturer and asking them the value of that specific resistor by including the number like you did in your post R14. If you can find a wiring diagram for the product, it should tell you the value of the resistor also.
I hope this helps you getting started in solving the issue.
If you would not mind, please rate my help. I would greatly appreciate it. Thank You
Feb 07, 2010 | Makita 2 Bl1830 18v Battery,dc18ra Charger...
Charger died.
It is usually a current limiting resistor anyway... so I would think that about 100 Ohms should be all good, you generally need about 250 - 300mA to charge ya batteries. It is simple Ohms law calculation.
Feb 04, 2010 | Drills
Same problem here.
If you're only reading .18 volts DC at the charger itself, then it's time to replace the charger.
It's probably some inexpensive Electrolytic Capacitors inside the charger that have bit the dust.
Here's info about Electrolytic Capacitors,
1.http://en.wikipedia.org/wiki/Capacitor_plague
2.http://www.capacitorlab.com/visible-failures/index.htm
Both sites relate to computer motherboards and computer power supply's, but know, that there has been a problem with 'Caps' for all kinds of electronic components, no matter what they are, therefore these same visual signs of failure apply. (Sorry about the run on sentence!)
3.http://www.absoluteastronomy.com/topics/Capacitor_plague (Read the entire article, and my statement above will become more clear)
Jul 13, 2009 | Black & Decker 14.4 Volt Battery Charger...
Was given a Coleman power drill, model CMD8189. The charger is inoperable. The two resisters on the charger internal circuit board have been fried. The resistor codes have been burnt off, so I cannot
I need the same, but found a Makita multi-voltage charger and have been able to use it. The package says It is for Makita batteries only. HItachi also makes a universal battery charger. I found both at my local Lowe's. The Makita was originally $69, but was marked down to $25. The Hitachi was around $70. You can find either one for good prices on Ebay or Amazon.
May 05, 2009 | Coleman Cable Coleman 18 Volt Combo Drill...
Drills Logo
268 people viewed this question
Top Black & Decker Drills Experts
JOHN LAPIER
Marvin
Marvin
Thomas F. Schneider
Are you a Black & Decker Drill Expert? Answer questions, earn points and help others
