This is what the manual says:
PROTECT"and "PUSH POWER" appear
alternately.
•A strong signal was input.
Press ?/1 to
turn off the power, leave the system
turned off for a while, then press ?/1
again to turn on the power.
•Check the speaker cables in case
"PROTECT" and "PUSH POWER"
appear alternately again after you turn
the system on.
SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Look at your memory card. SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
MHC-DP900D HAD SAME PROBLEM- PROTECT, PUSH POWER. TRACED CAUSE TO AMP. DC PROTECTION CIRCUIT ON AMPLIFIER BOARD. ACTUAL FAULT WAS A SHORT CIRCUIT OF THE AMP. IC LEFT CHANNEL OUPUTS (STK412-030 PINS 10 & 11) EXCESSIVE SOLDER APPLIED DURING MANUFACTURE HAD PROBABLY BEEN HEATED UP ENOUGH DURING USAGE TO BRIDGE THE PINS. CURRENTLY USING THE UNIT WITH RIGHT CHANNEL ONLY UNTIL I PURCHASE A NEW IC. BYPASSED DC PROTECTION FOR LEFT CHANNEL BY ISOLATING INPUT TO DC DETECT TRANSISTOR.
This is what I could find, it looks like it will need serviceing unless you can do it yourself, it can be deadly if you don't know exactly what you are doing.
Thanks for the fixya rating, hope this helps
hi, everytime i switch on my sony hi fi it the display screen says protect push power. It won't let me do anything not even put cd's in. If you could help that would be very much appreciated.
