Error message Received the following error: ''Received the following error code: ''ink system has failed. Unable to print. Refer to printer documentation. Error: 0xc18a0001 Turn power off then on again'' I tuned power off then on again & did not work
I have a HP photosmart C5180 all in one. It has an error message that says....Ink system failed unable to print refer to printer documentation error OXCa0501. By chance would you know what to do to fix it? Thanks
Hi ok then tryI found this I know your error not in here but it may work for It worth a try nothing to lose and it may work.I know your error code is not in this but it some times it clean the error with this type of error number you can gave it a go try not harm itError code: 0xc18a0201, 0xc18a0206, 0xc18a0306, 0xc18a030a, 0xd0620130, 0x887dd03a, 0xd05d010d, 0xf0af8004, 0xc19ac3ff, 0xc18a050...
Reset the product: 1.Without turning off the product, disconnect the USB cable from the rear of the product. 2.Remove the cartridges from the product. 3.Wait for the 'Insert Cartridges ' message to display on the control panel. 4.Disconnect the power cord from the back of the product. 5.Wait 60 seconds. 6.Reconnect the power cord. If the product does not automatically turn on, press the Power button ( ). 7.Reinsert the cartridges, and then close any open doors on the product. 8.If you receive a prompt to print a calibration page, do so. 9.Reconnect the USB cable to the rear of the product, and then try printing again. Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
IssueAn 0xc18xxxxx or 0xc19xxxxx ink system error code displays on the front panel. The printer cannot copy, receive faxes, or print. Solution Press the On button to turn the printer off. Unplug the power cord from the back of the printer. Remove all the ink cartridges. Wait two minutes. Plug the power cord into the back of the printer. Press the On button to turn the printer on. Install the ink cartridges when prompted. If the error code does not display, the issue is resolved. If the 0xc18xxxxx or 0xc19xxxxx ink system error code displays on the front panel, service the printer.
Ink system failures is a very serious problem on HP printer systems. If
you have this problem you should be ready to replace your printer.
However there are still troubleshooting steps that you can do to try to
resolve this problem. try this Ink System Failure Trouble shooting guide.
