Dell Latitude C610 Notebook Logo
abdi munawar Posted on Sep 22, 2013
Setting bluetooth - Dell Latitude C610 Notebook
Janarthanan GV
Level 1:
New Friend:
Greenhorn:
A rookie expert who has answered 20 questions on their first day.
  • Contributor 27 Answers
  • Posted on Jun 26, 2014
Janarthanan GV
Contributor
Level 1:
New Friend:
Greenhorn:
Answers
27
Questions
0
Helped
1774
Points
30
Press function F2 and set the blue tooth settings.Go to control panel and change your settinsg
Where in settings is Bluetooth on my Luxor 55" tv
The exact location of the Bluetooth settings on your Luxor 55" TV can vary depending on the model and the operating system it uses. However, here are some general steps that can help you find the Bluetooth settings on your TV:
  1. Turn on the TV: Press the power button on your Luxor 55" TV to turn it on.
  2. Access the settings menu: Press the "Menu" button on your TV remote to access the settings menu. This may also be labeled as "Settings," "Options," or "Tools."
  3. Look for the Bluetooth settings: Scroll through the menu options and look for a section labeled "Bluetooth" or "Wireless and networks." The exact location of this option may vary depending on your TV model and the operating system it uses.
  4. Enable Bluetooth: Once you have found the Bluetooth settings, toggle the switch to turn on Bluetooth. You may also need to set the TV to "discoverable" mode so that it can connect to other Bluetooth devices.
If you are unable to find the Bluetooth settings on your TV or are having trouble connecting your Bluetooth devices, you may want to refer to the user manual or contact Luxor support for further assistance.
How do I make my hp officejet 100 discoverable
Extracted From the USER GUIDE (download here) http://h10032.www1.hp.com/ctg/Manual/c02648771.pdf
Set up the printer for Bluetooth communication
The printer allows you to print documents from
Bluetooth devices without a cable connection.
Simply print from a Bluetooth device such as a PDA or camera phone. You can also use Bluetooth technology to print from a computer to the printer.
Set up a Bluetooth wireless connection
This section describes how to set up and configure the device for a Bluetooth wireless connection.
You can configure Bluetooth wireless settings during software installation, or you can configure settings later using Toolbox (Windows), HP Utility (Mac OS X), or the Toolbox software for PDAs
(Windows Mobile). For more information, see Printer management tools.
To connect the printer using Bluetooth communication (Windows)
NOTE:
If you are using an external Bluetooth adapter for your computer, specific instructions for adding the printer might be different. For more information, see the documentation or utility provided with the Bluetooth adapter.
1.
If you are using an external Bluetooth adapter for your computer, make sure your computer is started and then attach the Bluetooth adapter to a USB port on the computer.
If your computer has Bluetooth built in, just make sure the computer is started and that Bluetooth is turned on.
2.
On the Windows taskbar,
click Start
, click Control Panel
, click Hardware and Sound
, and then click Add a printer
- Or -
Click Start
, click Printer
or
Printers and Faxes, and then double-click the Add Printer icon
or click Add a printer
3.
Follow the onscreen instructions to finish the installation.
To connect the printer using Bluetooth communication (Mac OS X)
1.
2.
Click
System Preferences in the Dock, and then click Print & Fax
3.
Click + (Add).
4.
Select the entry for the printer in the list with Bluetooth beside its name, and then click Add
5.
Set Bluetooth security for the printer
You can enable the following printer security settings:
• Require passkey authentication prior to someone printing to the printer from a Bluetooth device.
• Make the printer visible or invisible to Bluetooth printers that are within range.
• To enable these settings, you can use Toolbox (Windows), HP Utility (Mac OS X), or the Toolbox software for PDAs (Windows Mobile). For more information, see Printer management tools.
Set up the printer for Bluetooth communication 93
Use a passkey to authenticate Bluetooth devices
You can set the security level of the printer to either
High or Low
• Low : The printer does not require a passkey. Any Bluetooth device within range can print to it.
NOTE:
The default security setting is Low
. Low level security does not require authentication.
• High: The printer requires a passkey from the Bluetooth device before allowing the printer to send a print job to it.
NOTE:
The printer ships with a predefined passkey that is set to six zeroes "000000".
Set the printer to be visible or not visible to Bluetooth devices
You can set the printer to be either visible to Bluetooth devices (public) or not visible to any (private).
•Visible : Any Bluetooth device within range can print to the printer.
• Not visible : Only Bluetooth devices that have stor
ed the device address of the printer can print to it.
NOTE:
The printer ships with a default accessibility level of Visible
To reset to factory default settings
NOTE:
Using the following instructions will reset only the device's Bluetooth settings.
1. Press and hold down (Power button).
2. While holding down (Power button), press (Cancel button) 4 times, then press (Resume button) 6 times.
3.Release (Power button).
Asus laptop how do you get no wifi
Turn on your computer and locate the Wi-Fi icon.
This could be located on the upper row on a laptop it will have the radiation look (((·)))
Make sure its pressed on.
When you turn on an Asus laptop's Bluetooth function, you allow cell phones, headsets and any other Bluetooth device to be synced with or found on the laptop.
You can use Bluetooth on a laptop to listen to music on a headset or to sync and transfer files from the computer to the device.
If the Asus laptop has Bluetooth wireless technology preinstalled, you can enable Bluetooth access by changing the settings in the control panel.
Click the "Start" menu and open "Control Panel."
Select "Hardware and Sound" and "Bluetooth Devices."
If the "Bluetooth Devices" option doesn't appear, your laptop does not have Bluetooth capability.
Open "Bluetooth Settings."
Click the "Allow Bluetooth devices to find this computer" checkbox in the "Options" tab.
Click "Apply" to save your settings. Click "OK" to close the window.
Change settings for a Bluetooth enabled device
http://windows.microsoft.com/en-US/windows7/Change-settings-for-a-Bluetooth-enabled-device
Not sure how to connect phone to hilux bluetooth
The option for pairing bluetooth with phone is available in thephone's settings. Enable bluetooth under settings, and ensure that the bluetooth device is set to 'discoverable' or 'pairing' mode. Simply scan for devices from the iPhone via the bluetooth settings.
2helpful
My Laptop specifications are, ASUS F80Q, dual core, 3 gb ram, Windows 7 ultimate. when i first installed windows 7 (long time ago) it detected my bluetooth device, but now in the middle suddenly it...
Seems like your Bluetooth and Wifi settings are disabled from BIOS.
On laptops usually there is a setting in BIOS where you can disable/Enable Wifi+Bluetooth. Shutdown computer Turn on computer and press "F2" to go to BIOS settings Find settings for Wifi+Bluetooth and set it to default.
Save settings and restart computer You will be able to see your Bluetooth and Wifi.
Hope this works
1helpful
Bluetooth is not working
charge-up your bluetooth head set.
set your bluetooth option of your hand set- go to application settings and look for connectivity (bluetooth) press On button.
click on my visibility : select ON mode
turn on your bluetooth headset
from your phone, select the search button
it will appear the name or brand of your headset bluetooth
select it by using your keypad browser, then ok
the phone will be pairing it for conectivity
if password asked: 0000 or 00000 is the code.
make sure you have the same version between your bluetooth and your handset ex: 2.0 etc
Jan 16, 2011 • Cell Phones
1helpful
Hi i just bought a lg gw300 and i can't set up my bluetooth i don't know how to set up the "passcode".
Your "Passcode" is setup when you "Pair" with another Bluetooth appliance.
e.g If you want to connect to your friends phone via bluetooth to send a picture you would send via bluetooth and search for bluetooth device. When you select the one you wish to connect to it will attempt to "Pair" with it. At this point a "Passcode" maybe asked for if the bluetooth device you are pairing with has one set. If it does then you need to ask the person who owns the device for the "Passcode" before your picture can be sent/recieved.
Normally if you wish to set a passcode for your device it will either be in your bluetooth settings. Possibly even in "Security" in the bluetooth settings or it may just be in your "Security" settings.
5helpful
6answers
How do i turn on the bluetooth on my netbook msi
Is it equipped with bluetooth? Do a search for bluetooth on your computer and it should bring up the bluetooth icon. Go "start", "search", then "all files", and type in bluetooth and search.
T Mobile Wing bluetooth and music help please
Hi fazioli73,
With Bluetooth enabled cell phones, if it has a music player, the only device the music player will recognize to output audio is a set of Bluetooth Headphones, not a Bluetooth Headset.
Once you have the Bluetooth Headphones, set them into pairing mode. Then go into your Bluetooth options in your phone, and go into add/search for device. Once your phone recognizes your Bluetooth headphones, and you have it set as your main Bluetooth device, your music player should play through the headphones at that point.
Sincerely,
Gina, Communities Connection Manager
Creating meaningful communication in a virtual world
Setting up a bluetooth headset to my aspire 9500 notebook
you need to install first the bluetooth software on your PC, then create a connection via the console of the bluetooth program, activate your headset then go to your bluetooth software on the PC, then scan for bluetooth device, once the device is found, choose the headset icon, and set the settings to your liking.
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
