Which model do you have? The Ergorapido EL1014A has a charging station. On that model, the charging adapter plugs into the port on the bottom of the floor section of the charging station. This port is below the wall section of the charging station. For the Ergorapido Lithium Ion Plus 2 in 1 vacuum, EL2055B, the charger plugs into a port on the back of the main vacuum above the neck to the roller brush head. For a picture of the charging port location, see https://moderncastle.com/vacuum-cleaner-reviews/electrolux-ergorapido-vacuum-review/ . Scroll down to the Battery section to see the appropriate image.
I hope this helps. The manual for the EL1014A is much clearer about charging the vacuum.
Iy is either the charge or batteries, if you have a DMM or access to one test the charger by measuring output,
best solution is to change e batteries and charger, You can look in line amazon sell both, but may be less on eBay, Watch this link
this sounds totally silly but is the power button on the vacuum actually off? Had the same problem, where the battery was completely empty i didn't know my son had switched the vacuum on put it on charge and the light was flashing. I took it off the charging stand pressed the power button then put it back....now charging perfectly. Anyone who doesnt have this appliance will think you sound stupid but its just a clicky button so visually the button looks the same on or off.
Let me say this; The battery replacement for the Electrolux is not a owner level replacement procedure. However, you can replace the 4 original EMX1600sS batteries . The battery model is Tenergy 2/3A Size Rechargeable Battery 1.2V 1600mAh NiMH W/ Tabs Those are a little smaller than the originals but with the same capacity of 1600mAh and can be easily found in the web. Anything under those specs should work. These types of battery's will cost about $15.00 on the web. The battery's are in the hand held unit bottom or back side area, you access them by taking out all the screws in the back side of the hand unit.
