SOURCE: error code h97, on a genius prestige microwave -
Hello :
Troubleshooting of Inverter Circuit (U) and Magnetron .
This oven is programmed with a self diagnostics failure code system which will help for troubleshooting, H97, H98 and H99 are the provided failure magnetron and inverter circuit problem areas. This section explains failure codes of H97, H98 and H99. H97, H98 and H99 appears in display window a short time after start key is pressed and there is no microwave oscillation.
WARNING :
The microwave is capable of giving you a serious electrical shock even when it's unplugged , so I recommend you to call a repair technician for help .
please don't forget to rate .
good luck .
SOURCE: My Panasonic NN-ST657W microwave has
This oven is
There is not a lot the layman can do except maybe to try a new magnetron.
It is a job for an experienced Panasonic Microwave repair man.
Testimonial: "That's what I was dreading. Might be cheaper to buy a new microwave than to have a new magnetron put in... sucks only 3 yrs old. Thanks anyway."
SOURCE: Panasonic Microwave Oven showing error
here is the link of how they troubleshoot this code they do not advise anyone to perform this test unless you know how to discharge the capacitors and there is also an extremely hi amount of electricity it might be best to call a service tech but you can have a look at the link usually that error pertains to the magnetron or the invertor haveing an issue http://www.applianceaid.com/micro_faultcodes.html
if you have any further questions message me back Thanks and please remember to rank how this opinion has helped it allows me to help others in the future in similar situations Thanks Rick
SOURCE: panasonic nn-sn778s microwave shuts off and no heat- H97 is error code
H95, H97, H98 or
H99 mean that there's a problem with your inverter,
magnetron, or digital programming circuit.
Due to the lethal
voltages used and produced in inverters, I do not recommend that an
inexperienced person work on these.
You can find an authorized Panasonic servicer here.
In Canada, you can find an authorized Panasonic servicer here.
We're
happy to help you with free advice and we'd appreciate your thoughtful
rating of our answer.
This oven is
