RCA RCU300TR SystemLink 3 Universal Remote w/batteries Logo
Jerry Upp Posted on Sep 21, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Can a Sanyo tv be controlled by a RCA Systemlink 3 tv remote?
Gilbert Straight
Level 2:
Sergeant:
  • Expert 504 Answers
  • Posted on Sep 26, 2013
Gilbert Straight
Expert
Level 2:
Sergeant:
Answers
504
Questions
Helped
52256
Points
850
Yes, If you know how to do a Code search on the remote.
Re: need codes for rca remote Systemlink 3 for 22729 tv
Katina, Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
https://www.remotecodelist.com/remotes/rca/rca_systemlink_prog.html
RCA universal remote code lists RCU Series Systemlink series direcTutor
Electro help RCA SYSTEMLINK 3 UNIVERSAL REMOTE TV SETUP CODE LIST SETUP...
Need codes for programing my RCA Systemlink 3 remote control to a Sanyo tv
Hello Barbara370,
Here is a link for youl.
http://www.universal-remote.net/rca.html
Hope this helps you out.
Cheers Little Dish Fitter
4helpful
Code to program my remote systemlink 3 rca to my jvc televsion
Im trying to program my remote to my orion televisison how do i do that?
1helpful
Need code # for rca tv
If your remote control has a search button, this is how you do it-------- User submitted information for the SystemLink 3: To clear things up and make it simple, here is how to program the RCA Systemlink 3 remote:
****WITH DEVICE TURNED ON****
  1. Press and hold the "Code Search" button until the LED lights, then release. LED will stay light.
  2. Press and release the device key to be programmed. LED will go off when button is pressed and back on when released. LED remains on.
  3. Press and release the remote On/Off (power) button as many times as required to turn your device OFF.
  4. When device turns OFF, press and release the ENTER button.
Test remote on device, if ALL functions do not work, repeat above procedure.
***IMPORTANT NOTE*** Count how many times you press the On/Off button. If ALL funtions do not work and you need to repeat, you don't want to stop at the same non-working code. For instance, if it takes 23 times to turn your device off and after testing, the remote does not control all functions, repeat steps 1-3 BUT when the device turns off at the 23rd time, turn it back on using the power button ON THE ACTUAL DEVICE then continue with step 3 and 4 from above.
Programing trouble
I have an RCA remote SYSTEMLINK 8A-V and need to know how to program it to work my Sanyo Television. ...
39helpful
16answers
SYSTEMLINK 3 RCA UNIVERSAL REMOTE CODE 4 A MAGNOVOX TV
MY TV IS SANKEY AND I CAN`T FOUND THE CODE IN THE LIST OF MY SYSTEMLINK3 RCA, Please i need help! Thank`s
Top RCA Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
