Whistler is leader in international state of the art electronics and automotive laser radar detection systems Visit our website to see our latest products buy product accessories...
Hi!!
This units have fuses, they are located right where the power wires come in and go out. With some luck, all the damage could be a blown fuse.
Thank you for using FixYa.
A 4 THUMBS rating is appreciated for answering your FREE question.
There are two possibilites: the first is the over 400W power draw, the other is how you have the inverter connected. Do you have the inverter connected directly to the battery terminals (the clips) not the outlet plug (cigaretter lighter)? This is needed for any load over 80W and under 400W. (the inverter can handle a load demand over the 400W limit but only for short periods (800W).)
What is the load that your PC pulls (Is it a laptop or a desktop)? The laptop in my home has either a 65W or a 90W load (depending on the battery and the AC adapter we are using). Desktops take much more power (usually).
The problem of your inverter is from your battery .your laptop and dvd player requires little current to operate.But you tv requires more power to run, if your battery is low you it will not last for 3 minutes. If your battery has a low current rating, it will also be a cause, for example, if it is below 100ampere hour. Lastly if your battery is bad i.e. if it reads below the stipulated dc voltage Require by your inverter to operate.
Ah, I see, it seems what you have is a power pack. If so it would contain a gelcell battery, probably 12 volts. If this is true, then you may charge it with any 14-16 volt wall charger. You have to make sure you observe correct voltage and correct polarity when connecting up. Also you may have to obtain and change the plug on the charger wire. I'm assuming the battery DC output is inverted to AC and you use it to power small AC appliances.
