Cars & Trucks Logo
Posted on Apr 18, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Problem starting my 2003 dodge ram
I have a 2003 dodge ram 1500 5.7l hemi. Last night i tried to start it and the key wont turn, the steering wheel wasnt locked, and i tried for a half hour to get it to turn, this has happened once before, and i got it turn and start after wiggling the key in there for 5 min and turning wheel as hard as i could, but its not working this time. took it to autozone because check engine light was on, and they said it was the ignition coil. The key goes in but it just will not turn its like the ignition is locked. What do i do to fix this?. Should i change the ignition coil, will that solve the problem.
  • Anonymous Apr 24, 2009
    i got a problem where my truck can be running and i can walk away form the with WITH KEYS IN HAND and yeah... when i shut the truck off it don't shut all the way off and its killing my battery...
Anonymous
Level 2:
Sergeant:
Champion:
  • Expert 255 Answers
  • Posted on Apr 19, 2009
Anonymous
Expert
Level 2:
Sergeant:
Champion:
Answers
255
Questions
Helped
93102
Points
638
No if you took it to autozone obviously you have a good ign coil.im sure you have tried turning the wheel at the same time you turn your key. other than that i would replace the lock cylinder and key.
hope2help shack
5 Related Answers
Anonymous
  • 83 Answers
  • Posted on Feb 15, 2010
SOURCE: 2005 Ram 1500 4wd HEMI PO406 - EGR
Hey greenlee99, your best bet would be to grab one these manuals so that you have pictures and diagrams along with step by step instructions. It will tell you what tools and parts you need. Can't go wrong with having it.
ZZZoom
  • 151 Answers
  • Posted on Sep 14, 2009
SOURCE: 2004 ram 1500 hemi 5.7 alternator
You need to release the belt tenion before, removing the alternator. The engine is equiped with auto tenioner.
Anonymous
  • 83 Answers
  • Posted on Oct 05, 2009
SOURCE: how do i change the power steering pressure switch
From the Factory Service Manual, you can get one relatively cheap from www.promanuals.net. Here is a link to your 2004 Dodge Ram Service Manual.
The power steering pressure switch is installed in
the power steering high-pressure hose (Fig. 9).
(1) Disconnect electrical connector from power
steering pressure switch.
(2) Place a small container or shop towel beneath
switch to collect any excess fluid.
(3) Remove switch. Use back-up wrench on power
steering line to prevent line bending.
Anonymous
  • Posted on Apr 26, 2009
SOURCE: problem with starting my 2003 dodge ram
My father has the same problem with his 2001 Chrysler Sebring, the key will go into the ignition switch but wont turn. Called the dealer and seems the tumblers inside the ignition have gotten stuck, the solution... put the key in the ignition and tap it gently with a hammer (plastic tip if you have it) and it worked fine. Not sure what the guys at Autozone are pull but on a Ram 5.7 Hemi there are individual coils, not one, I should know I also have a 2003 Ram 1500 and have changed the plugs (not fun)... I have a code scanner (Hypertec) and when I've gotten a check engine light I check it with the scanner. Turned out mine had a problem with the air sensor in the intake. $15 part fixed the problems. Good Luck.
Anonymous
  • 249 Answers
  • Posted on Jan 05, 2010
SOURCE: replace timing chain on 03 dodge ram 1500 with 5.7 hemi
i have an 02 and i purchased a repair manual from autozone
2004 dodge ram key wont turn tried the hammer trick does not work how can I remove the cylinder without the key turning
Hi Richard:
Before resorting to too much force, try turning the steering wheel. One way will be really stiff, the other not so bad. Gently wiggle the key as you apply pressure to move the steering wheel.
If it's an automatic, it also won't hurt to jiggle the shift lever.
Patience.... you'll get it.
2003 dodge ram 2500 front end clicks
Most likely U Joints in the front axles. These will only turn in 4 wheel drive.
2004 dodge ram hemi losing fuel pressure
i need to change my oxigenpipe for a dodge 04 1500 but i dont now where to find it
The ignition on my 2003 dodge grand caravan is locked up. Key wont turn but will go in and out
when you are trying to turn the key try turning the steering wheel too sometimes the steering lock gets hung up and this usually frees it up
1helpful
2004 dodge hemi WONT START???????????
You may want to check your coil packs or distributor. Sounds like moisture is gettin in there. Im a mechanic just had the same problem with a 93 crx
Problem with starting my 2003 dodge ram
1helpful
2003 dodge hemi 2500 wont start
You probably spun a main bearing
I cannot turn the steering wheel in my truck, it worked fine last night
have you tried putting the key in the ignition and moving the wheel at the same time? sometimes they are stiff like that
Top Dodge Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
Thomas Perkins
Thomas Perkins
Are you a Dodge Expert? Answer questions, earn points and help others
