focalprice technology Ainol NOVO 8 8"" Android 2.2 Amlogic 800MHz Tablet PC" Logo
Ted Ball Posted on Sep 21, 2013
I am looking for a driver for Novo 8 Discover(Ainol) Tablet so I can download from Windows 7/8
Bill
Level 1:
New Friend:
Greenhorn:
A rookie expert who has answered 20 questions on their first day.
  • Contributor 58 Answers
  • Posted on Oct 20, 2013
Bill
Contributor
Level 1:
New Friend:
Greenhorn:
Answers
58
Questions
0
Helped
6607
Points
90
This is an Android tablet, so you can't use Windows on it.
Can I charge my Novos 7inch tablet through a usb cable attached to my computer there seems to be a problem charging through normal port
There are only so many milliamperes available to the whole USB bus on any computer. Having too many devices connected will cause not enough power to charge your tablet.
Try a wall adapter.
Power port needs repaired
Are you sure it is the port that needs fixed, or is it your usb cord you plug into? If it is the port you need to send the tablet in for a technition to repair. First try a new charger or usb cord and see if it works.
1helpful
Ainol Novo 10 Hero 10 won't turn on :( it appears dead :'(
Sounds like it is not charging.
The unit will power on momentarily if low batter but power off straight away
Get an electrical competent person to check the output of the power unit or use know good unit.
Ainol Novo 10 Hero Tablet won't turn on/off on power button... it only works from reset button... also auto rotate doesnt work... Also whole tablet gets stuck always after 10min useage... ideas???
I have same problem as you have: the on /off switch completely not work . It cannot start only way use the reset pin then cannot off.Mine also has freezing problem.I went to setting then go to factory reset erase all my data. The freezing gone but the on / off switch still not work then I think this could hardware problem. Only way is open it up.Since this is a traumata act I have to use as the last act.Meanwhile I set the display screen close in 2 minutes when want to stop it.Any one here have any better idea please help.
My ainol novo hero is frozen on home screen
The simple way to tempary solve this problem by just use a pin to insert to the small hole next to the power supply hole.this will turn off the set and start from begining(not reset to factory setting).If your problem back again then need to consider to go to backup and reset to reset to factory setting.It will lose all your data.If still not work contact the factory and install update firmware./
4helpful
3answers
try pushing in the mic button with a safety pin. That used to work on mine, now mine wont turn on at all. : (
Top focalprice technology Tablets & eReaders Experts
k24674
ADMIN Andrew
ADMIN Andrew
Are you a focalprice technology Tablet and eReader Expert? Answer questions, earn points and help others
