You can reset the laptop using this page from toshiba
How To Perform system recovery Windows 7 TOSHIBA FORUMS
SOURCE: How do I restore to factory setting Toshiba Satellite M35X S114
You need to have the restore disk that came with the machine or if you don't have it, then you will need to get a Windows XP cd and find the drivers for your hardware on Toshiba's Support website.
SOURCE: how to restore toshiba satellite factory settings
pls be more specific....
are you planing to format you machine....
what factory settings.....
SOURCE: how do I reset a Toshiba Satellite Laptop to its
you use the backup disk or purchase a windows installation disk please rate if i helped
SOURCE: how do i restore my toshiba p300-172 back to
a couple of ways to do that 1) if you have the recovery CDs supplied with the PC - then you can use these - put the CD into the drive and when it boots follow the instructions 2) If you have a recovery partition on the laptop - have a read here to see if you have one http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/outFrm.jsp?ofId=AskIris&searchString=recovery+to+factory 3) This link shows you how to use the partition http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/bulletinDetail.jsp?soid=2291088&pf=true basically as the PC boots TAP F8 key - from the menu that appears choose "repair your computer"
Testimonial: "tnx i just remembered it never came with a recovery cd but it did come with toshiba recovery disc creator, might give it a try wen i get some cd's."
SOURCE: I want to restore my factory settings on my toshiba satellite
If your model Toshiba laptop has a Restore partition on thehard drive then follow these steps to restore your Toshiba to the Out of theBox condition.
1. Press and hold the 0 (zero) key and at the same time, tap the power buttononce to switch on
your notebook.
2. When the machine Starts beeping; release the 0 key.
3. When prompted by the warning screen; select Yes to continue with the systemrecovery.
4. Select Recovery of Factory Default Software; click Next.
5. Select Recover to out-of-box state. 6. Click Next again.
7. Click Next to Start recovery.
8. Restart the Toshiba laptop when there restoration process finishes running.Follow the prompts that appear on the screen to set up the laptop's date, timeand language settings.
