Rubber grommets in fan blades pushed through blade and split the blade wood when attempting to snap blade on to post of blade bracket.
SOURCE: Hunter ceiling fan
Sounds like the remote receiver units (located where the mains connect to the fans) took a surge and have failed.
SOURCE: blade problem
The Hunter web site should have them. If not I have found simular ones at Radio Shack and also have ordered them from parts suppliers like Mouser, Digi-key, Allied electronics Mat electronics. All of which can be found and ordered from online.
SOURCE: Fan Parts Hunter Fan Type C Model 25436 No. 017626
Cool Breezes
Cool Breezes carries parts for old fans that Hunter no longer carries parts for
COOL BREEZES
1335 W Campbell RdRichardson, TX 75080
(972) 690-4580push2talk //-->
SOURCE: Hunter Douglas Ceiling Fan Does Not Work
Try Cheyenne Lamps 2000 E. 17th Street Little Rock AR
501-374-2829
SOURCE: Similar problem: Does Hampton Bay Vaulted Ceiling Mount exist?
Ok so here is the deal. No there does not seem to be a Hampton Bay specific mount. The mount that comes standard in most of the Hampton Bay fans can handle the angle of most standard (read: small) angles. I do not know if it will be the case with all Hunter products, but the adapter for the Hunter fan that I replaced, worked with my new Hampton Bay. So now, I have from the downrod up is from the original Hunter fan. Hope this helps.
