I've subscribed to caller ID. Is it possible to view the caller on the display and if so, how to set this up?
The KX-T7731 is a proprietary system phone. You have a Panasonic phone system. Caller ID is transmitted between the first and second ring but the phone system itself is the only part that gets this information. The system has to be compatible for caller ID and it has to collect the caller ID data and send this information to your phone(s). Your phone can be used on many different Panasonic phone systems. The phone's part number does not help you. First thing you need to do is find out what system you have and if it has caller ID. The phone system part number should start with KXT like your phone.
I found this information athttp://www.panasonic.com/consumer_electr...
"Caller ID requires an optional KX-TA82493 Caller ID card"
I suspect that Caller ID may be turned off in programming as well by default.
Do you know the company that installed the system? Do you have the ability to make system programming changes yourself?
I found this also:
One KX-TA82493 is included with the control unit and additional two cards can be installed.
So, at least the first 3 lines should have caller ID... BUT it may be turned off in programming. The reason being is the caller ID is sent after the first ring so usually the ring you hear is delayed by 1 ring on a system using Caller ID. People would not want this on by default if not subscribed to caller ID service.
You press the round button that says ENTER press forward button 3 times press enter on Extension Directory Name? than press forward button again twice and press ENTER on incoming call log , it will show u last calls to view number press on to more button close to display, i hope it helps.
Caller ID Solution
You press the round button that says ENTER press forward button 3 times press enter on Extension Directory Name? than press forward button again twice and press ENTER on incoming call log , it will show u last calls with names, to view number press on to more button close to display, i hope it helps.
my phone system is a KX-TA824, which, according to its description has caller id capability that can be viewed on any phone on the system that has a view window. Given that fact, how to I tell it to show caller ID?
caller id
