I have an Onkyo subwoofer SKW-530 which is part of a home theatre Onky HT-S780. Subwoofer does not work..no LED light and no sound. Rest of the system is fine. Any advice? If the LED does not light does that mean no power?I have checked the power source and it is fine
I fixed my subwoofer. The resistor at R16 (right next to the fuse) was the fried component. I removed it and replaced it with a 13K ohm 5 watt metal oxide resistor (from Mouser Electronics if not available locally). Works fine now. I got the solution and the circuit schematic from an audio hobbiest at diyAudio.com. This is, evidently, a fairly common problem.
Onkyo subwoofer shuts down system when the volume is turned up from min
I have an onkyo subwoofer SKW-30 which is not working. No power light. I removed the circuit board and a component (probably resistor) looks fried. I need the schematic to get the right part. Onkyo can't furnish, but referred me to Sams publications for the shop manual, which is $38. Does anybody else have knowledge of this speaker?
I have a 12" JBL sub that does not power up - i replaced a blown fuse in it - but it still does not power up??
rmy subwoofer quit producing sound skw-30
i took the boartd out to look at it and found a looks like a burnt resistor
right below the fuse holder and a output connector for your input to receiver is pretty scorched as well i need help if is not worth to put money into lett me know
i'm a guy that don't give up if i can fix it i'll try
[email protected] thanks
I HAVE POWER TO THE SUBWOOFER AND WILL NOT WORK NO SOUND AT ALL NO CRACKING OR SQUEALING JUST NOTHING AT ALL.
