I use a Optical Trackman from Logitech and have foound that the contacts on the left click get dirty and won't work right or work partially. Especially frustrating when trying to highlight or shoot on FPS games. I took mine apart, just the housing , the electrics stay , and cleaned as well as I could , then blow it out with canned air. Got mine working again. My guess would be dirt or that button is worn out. Logitech has discontinued many of the Trackballs so a replacement may not be possible
SOURCE: Unable to drag and drop files
let me whether u r not able to drag it from a folder to another or drag it to a start up or quick launch .
1. if you want to drag to startup grpoup or quick launch then go to :-
a. Right click on the task bar goto properties , select it
b.select start menu tab select customize
c. Again select advance tab and check the option Enable dragging and dropping. pls find it. it is in the second line .
now u will be able to drag and drop .
SOURCE: My Logitech cordless mouse MX 700 is being eratic.
There could be a sensitivity problem with the mouse before installing new drivers and software you can try going to the mouse settings to see if there's an adjutment problem,
also replace the battery if it's low, good luck.
SOURCE: Logitech Cordless TrackMan Optical Trackball connection
you are probably better off buying a new one
unless you are lucky enough to find a used one
SOURCE: I can no longer swipe content by holding down my left mouse to highlight and copy
If your mouse is not highlighting properly...
1. click start and go to Control Panel
2. click on Printer and Other Devices
3. scroll down and click Mouse
4. under Buttons click box that says Clicklock
5.press apply
