MSI K8N Neo3-F Motherboard Logo
Posted on Apr 17, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
New tower Need to hook the power SW, power Led+ & negative,Hdd Led reset Hdd led, usb and audio to the MSI k8n Neo3-f motherboard thank you
Anonymous
Level 3:
  • Master 674 Answers
  • Posted on Sep 09, 2009
Anonymous
Master
Level 3:
Answers
674
Questions
0
Helped
304878
Points
1997
The symbol is there writen there on the board or abrivation you can follow it.. like( pwr sw/ Hddled/ spkr..
1helpful
I dont know how to fix the Front Panel Audio Connector. And I dont understand what is ATX power switches. I'll tell you what wire i have: H.D.D. LED, POWER LED +, POWER LED -, RESET SW and POWER SW....
Hi!
You have to make make the four Front Panel Connection as shown below: -
(IDE LED is the same as HDD LED and Ground means negative '-')
Hope it helps! Good Luck!
Thanks for using Fixya!
CreativeTECH
2helpful
2answers
Problem with the MSI 7050 v2.0 (HP dx5150) Motherboard Front panel wiring colour diagram please.... PWR LED, HDD LED, PWR SW, AND RST SW
You should read manual of the moterboard, there is wiring diagram that you need. But however, i suggest to you - take it to the expert, if you don't know how to do it.
Just bought a new tower case and cannot figure out where to plug in the power switch, reset switch, power LED and HDD LED wires.
With reference of your motherboard posted picture, opposite pci slot you will find a ten pin male slot where you can place your hdd, power, reset jack connection of your cabinet
How to connect jfp 1
go to www.msi.com.tw for MSI guide , it should show you your motherboards front panel intel connection guide , it should be like this
PSWITCH PLED Open
RESET HDD SPK
1helpful
About MSI K8N Neo4
http://www.fixya.com/support/p298028-msi_k8n_neo4_f_motherboard/manual-15408
TRYING TO HOOK UP MU POWER BUTTON NEED TO KNOW
Hi there
The front panel connectors are mainly,
  • harddisk activity connector
  • power switch connector
  • reset switch connector
  • power LED connector
  • speakers connector
  • USB connector
Harddisk activity connector
This normally comes red in colour and is labeled as HDD-LED
Power switch connector
This comes green in colour and is labeled as POWER-SW
Reset switch connector
This usually comes grey in colour and is labeled as RST-SW
Power LED connector
This is usually green in colour and is labled as PWR-LED
Speakers connector
This speaker will give different beep sounds during boot to tell the user if there is any errors. It occupies 4 pins, however only 2 is important for the function. Be sure to connect the red coloured cable to the positive polarity and the black to the negative.
front_panel_connectors.jpg Front panel connectors pins on the motherboard
front_panel.jpg Front panel connectors from the casing
Good luck and thanks for using FixYa!!
2helpful
2answers
I need to know the sequence on how to connect my Power LED, Reset Switch, HDD LED, and M/B Switch up correctly. I have an MS-7142 VER:1 Can you help me?
Hi carlmtclem, your not alone when it comes to hooking up the right led connector to the MSI MB. Firstly, you need to know what wire color is positive & which is negative. Most commonly the color white is ground/negative. Wire colors do vary from case to case. So look at your case led wires. Which ever color is common for each 2-pin connector, is negative. (Except the speaker wire).
All other colors are positive.
(The speaker wire color for negative is usually black & red is positive).
Your MSI board has two separate sets of pins.
JFP2 is used for the speaker only. Do not connect the power led there.
Pin one for JFP1 is shown in the manual. Pin 1 is positive & pin 3 is negitive for the HDD-LED, ECT.
Thats it.
Need more information?
Post here.
Good luck carlmtclem!
Thank you for using fixya.
Mike
Hooking my Neo4 mobo back up.
Hi weeman105, case wire colors do vary from case to case. The most common case wire colors for negative are "white & black". All other colors like blue, green, red orange are most commonly "positive". The four pin connector with only the ends with wires is the internal speaker. Most boards use one set of pins where you hook everything up. The MSI K8N Neo4-F uses two separate motherboard pins, Front Panel Connectors: JFP1 & JFP2 as shown on the top page 2-19. Now that you know what color is positive & which is negative things should work out just fine.
Downloaded manual from MSI link: http://global.msi.com.tw/index.php?func=downloadfile&dno=4117&type=manual
If you run into any other troubles, just post & we'll go from there.
Good luck weeman105!
Mike
Top MSI Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Sean Wright
Sean Wright
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
