My garage fridge is leaking. Is is a GE, 162D7991G051, a backup fridge that has been in my garage for several years. The icemaker does not work, although I am not sure if that is because the line is not hooked to a water supply. This is not the issue; the water puddle in front of the fridge is! I think the guy who set it up in my garage had the long plastic line in back of fridge taped to the back somehow. Is this the line from the icemaker? If so, could the leak be caused by the fact that the line is now lying on the floor and not connected to anything? I do not see any water anywhere behind the fridge, underneath the fridge, nor any leak inside, or around seals. Where could the water be coming from? I can shake a little water out of the plastic tubing.I just don't know what, if anything, I should do with the excess tubing that is just lying on the floor behind the fridge.
My fridge has also been leaking but it's coming somewhere from the inside of the refrigerator. I only know because all of my food is wet. But that's so weird that there's no water beneath or behind your fridge. I bet that a professional would be able to find the leak fast, though, since they have probably seen a lot more leaky fridges than the both of us.http://www.bringerappliancerepair.com/lo...
