Hi Orville,
Your problem is all about your motherboard you need to updated to BIOS firmware to solve your problem.
Go to the gigabyte website then go to your motherboard page and download and updated to the latest firmware for your bios.
Steps in flashing BIOS
How to Reflash Motherboard BIOS
About updating BIOS...
The whole BIOS updating procedure should be treated with extreme caution. If you do not encounter any system instability or bugs with the current BIOS version, we suggest that you keep it. If you determine to flash BIOS, you are taking a personal risk of BIOS flash failure. Please contact your supplier or our distributors/resellers for further remedy in case system crashes unfortunately because of BIOS flash failure.
Before you begin...
1.
Please make sure the BIOS version you want to flash matches your motherboard model.
2.
If your BIOS is flash protected, please do not enable BIOS Flash Protection under Advanced CMOS Setup (AMI BIOS) or Advanced BIOS Features (AWARD BIOS) in BIOS menu.
3.
Never interrupt when you BIOS is being updated.
4.
Because BIOS flashing is potentially risky, if you do not encounter problems using the current version of BIOS, it is recommended that you not flash the BIOS. To flash the BIOS, do it with caution. Inadequate BIOS flashing may result in system malfunction.
Three BIOS Flash Utilities...
We provide three BIOS flash utilities at our website. Below are the overviews.
1 :
A BIOS flash utility embedded in Flash ROM. Not all motherboards have the Q-Flash, please use @BIOS or DOS flash utility to update BIOS if your motherboard does not have Q-Flash.
Features--
With this utility, you only have to stay in the BIOS menu when you want to update BIOS. No need to enter DOS or O.S. mode.
Caution--
Make sure you have a functional floppy disk with the correct BIOS version for your motherboard.
UEFI - Download PDF UserJust got a brand new gigabyte motherboard,when i - pdf.gif/a>
Download PDF User Guide
A Windows-based BIOS live update utility.
Features--
@BIOS helps you search for, download, and then update the latest BIOS in Windows operating system.
Caution--
Make sure your O.S. environment iJust got a brand new gigabyte motherboard,when i - pdf.gife.
UEFI - Download PDF User GuiJust got a brand new gigabyte motherboard,when i - pdf.gif
3 : DOS Flash utility
Features--
The flash utility is a combination of AMI and AWARD BIOS flash utility. You can use it with both AMI and AWARD BIOS.
Caution--
Make sure you have a functional DOS boot disk with the correct BIOS version for your motherboard.
I hope my solution may help you.
Thanks for using Fixya...;-)
SOURCE: Computer won't boot. When power
1st. check your memory sticks, if you have two, flip\flop them around. if you can replace (don't buy them if you can until you are sure that they are damaged) or substitute them for a "lower" value & frequency range. Just to see if the computer turns on.
p.s. are putting the computer together for the 1st time?, Was the computer working before the problem? if so you could have said so!
SOURCE: nFORCE3-A CPU fan & LED come on, nothing else, no beep or video
If the RAM is incompatible with your board then yes it would not allow a boot. Make sure your front panel power wire is plugged into the proper spot on the motherboard and retry. If it's the RAM then you will still have the problem. If it was the wire loose or in wrong spot then it should work. Hope this helps & please remember to rate my answer. Thanks.
SOURCE: Gigabyte GA-945GCMX-S2 Motherboard having display..
At first I thought your screen went black during the start up process. After seeing the bios screen. In which case I would've said it was a bios setting for the display. Then I realized that I think you mean that their is no display at all. When you push the power button. Only the monitor led light. So, it may be a problem with your RAM stick/s. You should make sure that they are properly seated in the mother board. If they are new, make sure they are compatible with that motherboard. If you can you should swap them out with known good ram sticks. You could also try installing a video card and see if you can get display to work through that one. Make sure your main power supply wire connector is pushed in all the way. Swap the power supply with a known good one if you can. If still can't get it to work you may want to take the motherboard out and inspect it for burns, cracks, and anything that doesn't look right. Maybe contact the manufacturer of the motherboard and ask them what you can check. hope this helps.
SOURCE: Just installed a new Gigabyte
motherboard to hard drive leads
Test all leads that attach to
your hard drive including electrical extensions,IDE,SATA the leads from your
((motherboard to your hard drive)) make sure they have a secure connection and
are not faulty or just replace them they could be faulty even something as small as an electrical extension or a
faulty fan lead can cause this problem
computer needs all of the data and electrical current to travel through every
device and to have an end to be able work properly a motherboard and a hard drive any leads between them will
fail before your motherboard or your hard drive if its a flat ribbon 40 pin
type IDE replace it this will be the first to fail check all electrical
extensions make sure they are securely seated even the cd/dvd floppy drives
need to have current go through make sure these drives are working hope this
helps
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch
floppy have secure connections and are not faulty or just replace them they
could be faulty ?
one bad lead will end with a computer error a computer needs its connections continue its
cycle and have an end to function properly
