SOURCE: Ewave OTR Microwave Oven, Model KOT-153UW. Light
We see (and repair) this
a lot. The problem is on the control panel, which
we regularly repair nationwide by mail for $39.95 postpaid in about a
week or so.
At
our Web site, you can get details of our service, plus we have a video
available showing how to remove a typical
over the range control panel assembly in under 5 minutes.
This light failure often
occurs when a bulb goes out and the filament
shorts, or when the bulbs are removed or installed without first
unplugging the oven from the power line. Either can cause such a
failure on the controller.
The lights can can be
inoperable or stuck on or no bright, too. Sometimes this will similarly
affect the exhaust fan operation or inside light, too.Feel free to contact me directly (and please remind me of your
full model number from the tag on the unit) for more information & help.
We're
happy to help you with free advice and we'd appreciate your thoughtful
rating of our answer.
William E. Miller, AS-EET
[email protected]
http://www.microwavedisplay.com
SOURCE: ewave panel is on lock
As per the owner's manual:
The oven operation can be locked to prevent the microwave from accidentally being turned on. All oven functions can be locked.
To Set: Touch and hold the CANCEL/OFF Pad for three seconds. The Display shows “LOCKED” and the oven beeps.
To Cancel: Touch and hold the CANCEL/OFF Pad for three seconds. “LOCKED” disappears from the Display and the oven beeps.
If this does not work, then try a hard reset: Unplug the unit for a
minute or so. Then plug it back in, set the clock and try again.
If it still fails, you probably have a problem with the controller.
We regularly repair such control
units for
customers nationwide by mail for $39.95 postpaid in about a
week or so with a one-year guarantee. It may cost a little more if you need parts, such as a new keypad.
information & help.
We're
[email protected]
Microwave Oven Control Panel Repair Nationwide
SOURCE: I have an Ewave microwave/range hood. How do I
Depends on the model number but here are some owner's manuals to check:
HTML clipboard
http://www.microwavedisplay.com/KOT131UB.pdf
http://www.microwavedisplay.com/KOT131UW.pdf
http://www.microwavedisplay.com/KOT152UB.pdf
http://www.microwavedisplay.com/KOT152UW.pdf
http://www.microwavedisplay.com/KOT153UB.pdf
http://www.microwavedisplay.com/KOT153UW.pdf
http://www.microwavedisplay.com/KOT170SB.pdf
http://www.microwavedisplay.com/KOT170SW.pdf
http://www.microwavedisplay.com/KOT171S.pdf
If you find that you still have trouble after replacing the bulbs, you probably have a problem on the circuit board.
week or so.
At
inoperable or stuck on or stuck in "night light" mode. Sometimes this will similarly
affect the fan operation or inside light, too.
information & help.
We're
[email protected]
SOURCE: change handle on ewave microwave
Normally you have to
separate the door panels (as shown in the attached photo)
and then you'll see the previously hidden screw(s) you need to remove.
Or you can watch a YouTube video (not a video I
made) that demonstrates how it's done.
In some cases, you then
have to gently rotate the handle to unlock it.
For more help from Daewoo / Ewave / Magic
Chef see here or their contact page or order
parts here.
You can download owner's
manuals for many Daewoo / Ewave / Magic
Chef models here.
We're
SOURCE: I want to buy the handle for my ewave microwave
You can order
Ewave parts here.
Normally
you have to separate the door panels (as shown in the attached photo)
and then you'll see the screws you need to remove.
Or you can watch a YouTube video (not a video I made) here that demonstrates how it's done.
