SOURCE: Mitsubishi WD-62628 power shuts off!
hold the MENU and DEVICE buttons when turning on the TV and get error code
SOURCE: Mitsubishi WS-65611
My mitsubishi 65611 is about 4 years old - I am getting a green overlay color on the screen can you advise what this might be?
SOURCE: My 10 year old 55 inch Mitsubishi rear projection shuts off.
The main board/switch is worn to the point it will not work anymore after a while, I been in the business for years, These are wonderful TV's, yes there are replacement parts but a quick fix your looking for here will be unsuccessful this is the reason I am providing my advice and take a chance on the rating your going to give me. Try www.ebay.com look for people that is saling parts for these TV's.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
SOURCE: Mitsubishi WS-65313 65 in. TV will no longer power up.
You should call a good TV Tech. This problem cannot be solved by a consumer. The one thing you might try is to unplug it from the wall for a few minutes and then try it again.
SOURCE: TV will not come on
The flashing LED may be telling you the source of the problem; note the relative spacing of the flashes and the number of times it flashes before staying off. The set is trying to tell you where it is sick but I suspect it is related to the power supply; the most common failure point of most modern sets. If you post back here as a 'comment' you won't have to repeat your symptoms.
