SOURCE: Sirius Sportster car kit - blown fuses
Try the other adapter and see if it works without blowing the fuse. If that fuse blows also, something is wrong with the radio.
SOURCE: No Power...Keep Blowing Fuses
you have a live going to ground meaning a live wire is touching another wire or touchin the caseing thus blowing your fuses
regards Doug
SOURCE: my fuse blows everytime i plug in my sirius radio
is that the only device that is blowing a fuse? if it is the only thing blowing your fuse you may need to replace the charger. check the fuse to make sure it is the correct size ( usually 10 amp). check the power adapter to make sure there are no loose connections or anything in the plug that doesn't belong there. unplug the radio from the adapter and plug the adapter in without the radio see if the fuse blows . if it blows replace the adapter. if it doesn't blow the fuse check the adapter to make sure it is the right one make sure the polarity is correct
