SOURCE: I have the date in
Hi
If you go to usa.canon com and search for 'a590', click on the link for the camera then click on 'drivers and downloads', now you will see the user manual in PDF format 4th on the list. You will find the instructions on pg 22:
Put the camera in shooting mode, set to auto, then press "Func Set" and use the down arrow to scroll down to the bottom row. Use the left/right arrow keys to unhighlight the date/time stamp and put it on "L" for the highest resolution setting for your camera.
Hope this helps. Good luck from Darntoothysam com (an affordable digital camera repair business)
Thomas
SOURCE: how to select date stamp on canon powershot a640?
You can print the date on image when Postcard is selected. The
date will be printed on your images even if it has not been set at the
computer or printer.
* Ensure that the camera's date/time is set beforehand.
* Set the camera to a shooting mode (except (Stitch Assist) or Movie).
* Press the <DISPLAY> button so that icons show on the LCD screen.
1. Check that appears on the LCD monitor.
- If it does not, click here to view the procedure for changing the resolution.
2. Press the <MENU> button.
3. Select (Date Stamp) in the [ Rec.] menu using the or buttons.
4. Select [Off], [Date] or [Date & Time] using or .
5. Press the <MENU> button to exit the menu.
6. Shoot the image.
- The Date or Date & Time will be embedded into the actual image.
SOURCE: Remove date/time stamp from photos
go to menu at shooting position. scrooll down to date menu and follow the succeding instructions.
SOURCE: Having to reset date and time
Solution:
Replacing the date battery PowerShot A510 and A520
Replacing the Date Battery
If the Date/Time menu appears when the camera power is turned
on, the date battery charge is low and the date and time settings have
been lost. Please purchase a lithium coin battery (CR1220) and replace
it as follows.
Please note that the first date battery may appear
to expire relatively quickly after you purchase the camera. This is
because it is installed in the camera at the point of manufacture, not
when you make the purchase.
Be
particularly careful to keep the date batteries out of the reach of
children. Seek medical assistance immediately if a child swallows a
battery since corrosive battery fluids could damage the stomach or
intestinal wall.
After purchasing the camera and turning on the power for the first
time, although the Date/Time menu will appear, you do not need to
replace the date battery.
If you ever dispose of your camera, first remove the
date battery for recycling according to the recycling system of your
country.
SOURCE: I have a Canon Powershot A560. The date and time
Think your problem is that you are looking in the wrong spot. Don't know why your manual is telling you to look there (are you sure your manual is for the A560)?
Your CR1220 date/time battery is located in the regular battery compartment. Look right beside your AA batteries. You'll see a little flap labeled "CR1220". Slide this open with your fingernail, and take the little coin battery down to your local drugstore to buy a replacement.
hello type its CR1620 3V , LITHIUM, need to take down back cover and front also ... dificulty 7/10
