Computers & Internet Logo
Benji Posted on Sep 18, 2013
If i pick up my phone (Ip phone SPA922), the next one starts ringing. If I pick up that one the next one starts ringing again. It says party ringing. How can I stop this
3 Related Answers
Anonymous
  • 8 Answers
  • Posted on Nov 07, 2008
SOURCE: Need help setting up spa922 ip phone
I believe for spa922 you can setup two VoIP connection or two phone numbers. Do you mean you can only use one connection or do you have multiple Spa922?
Anonymous
  • Posted on May 08, 2009
SOURCE: my linksys ip phone spa922 fail to boot completely,it stopped at the initializing mode.what can i do to resolve this
Hi there
Anonymous
  • 79 Answers
  • Posted on Aug 10, 2009
SOURCE: IP address
your voip enabled phone uses dynamic ip addressing so doesn't have a fixed ip. however if you want to configure the phone Connect the WAN port of the SPA922 to your network (router, switch or hub). Make sure that you have a DHCP server so that the SPA922 will get the IP address.
To login to web based administration follow the steps
Access the web based setup page of the SPA922. Verify the IP address through the LCD. Click Menu then press 9. It should show you the DHCP IP address. Open a browser and type that in the Address bar.
Click Admin Login .
Note: The SPA922 does not have a username and password by default. If you are asked for a username and password and you have not configured a password, it means that the SPA921 is locked by your VoIP provider. You need to obtain the password from your VoIP provider.
if this helps resolve your issue please vote for me. thank for using fixya.
How can I reset SPA to factory default?
I'm not sure about the 922, but other SPA phones can be reset without an admin password: hit the menu button, press 14 on the keypad, and OK the reset.
1helpful
How can I unlock a SPA922 that has ben Locked? I can´t do factory resett becouse it is locked!
Complete these steps:
1.On the Cisco IP Phone, press the Settings button.
2.Press **#
3.When the window displays Settings Unlocked, click the More softkey.
4.You now see the Erase softkey, which can be used in order to erase the configuration on the Cisco IP Phone.
I hope that this has been very helpful for you
2helpful
IP address
Click Admin Login .
2answers
Linksys VoIP SPA 941 personal Directory instructions
2answers
How do you answer another phone in the office by using your own phone
Ascertain from your system administrator the directed call pickup feature access code, this will allow you to pickup any ringing call as long as you know what ext number is ringing.
1helpful
Linksys CIT310 on Vista, other party's voice is not coming over the CIT310
I had the same problem. I got it figured out though. I called linksys tech support and they told me to update the drivers. At first I got no success. I eventually figured out that you have to manually deleted the old drivers throught your device manager before updating to the new drivers. The link for the new drivers is:
http//:www.linksys.com/vista
Once you get to this page click on the "download drivers" link and then scroll down until you see the 32 bit driver for CIT310 and click. I hope this helps.
Top Linksys Computers & Internet Experts
ExpressFiX
ExpressFiX
Grand Canyon Tech
Grand Canyon Tech
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
