HP PSC 950 All-In-One InkJet Printer Logo
Anonymous Posted on Apr 17, 2009
Won't fax or receive
Changed cartridge and received "press enter to align cartridge" message. Pressed enter then setup and this seemed to reset machine as time and date message appeared. When I try to fax I receive message as "No Answer" on other end, but their fax machine is operating. I cannot receive. Anyother suggestions to reset machine.
  • 1 more comment
  • Anonymous Apr 17, 2009
    Is used solely as fax. Is not connected through the computer. Will make copies and will print error report and setup information
  • megax01
    megax01 May 11, 2010
    Have you tried the phone line the printer is connected to, to see if there are any problems with it? You should hook that phone line directly to your phone and call the fax number thats giving trouble and see if you get a fax tone. If you have to request 1 that might be your problem right there.
  • megax01
    Is the printer printing at all? and are you using it directly with a phone line or through the computer modem?
Anonymous
Level 2:
Scholar:
  • Expert 87 Answers
  • Posted on Apr 25, 2009
Anonymous
Expert
Level 2:
Scholar:
Answers
87
Questions
0
Helped
35804
Points
163
You need to check the cable that goes to the wall.. Make sure it is plugged into the plug on the printer that says "line" or "wall" if it is plugged into the one marked phone... it will most likely not work.
After that (if it doesn't work) go through the setup procedures the manufactures manual has for that model
If you lost it your in luck HP has everything you need here:
http://h10025.www1.hp.com/ewfrf/wc/product?product=60259&lc=en&cc=us&dlc=en&submit.y=9&submit.x=7&lang=en&cc=us
MY HP FAXNUMER 640 WON'T RECEIVE FAXS AFTER I REPLACED TONER CARTRIDGE
The two aren`t related, you must have pressed a button that changed the `reception mode` to Manual from either `auto` or `tad`
1helpful
Hp c6180 fax not working. Message: Unable to send or receive faxes, press Os to continue Despite the all possible settings and driver updates, the fax has never worked. How can I fix this?
Follow the steps one by one
1. Press the Setup button - Press OK
2. Scroll to Tools - Press OK
3. Press OK on Run Fax Test
4. It will list you possible causes why you are not able to send/receive fax
If you cannot solve the issue with the Fax Report, you can do a semi-full reset on printer
( do not do the semifull reset on printer if connected to wireless, If you do so, the printer will loose wireless connectivity to router and you will have to setup the printer on router again )
Disconnect the power cord from back of printer ( when printer is powered on )
Hold the # and 6 button and while holding connect the cord back
This reset will Erase fax logs, wireless connectivity any other memory stored in printer
Follow the instructions on printer screen to re-align the printer and cartridges
Try to send/receive fax and it should work.
* Please rate this solution with Thumbs up and comment to help us improvise in providing better support
Says the paper is too narrow
Please find the solutions for your problem below:
DESCRIPTION AND SOLUTION – 1:
If you see this message on the front panel of the HP PSC 2210 when you are receiving a fax, check that the paper size is set to match the paper size in the paper tray. (You cannot receive a fax on 4 x 6 paper or on an envelope.)
Checking the paper size setting
  1. Press Setup .
  2. Press the right arrow until you see 3: Basic Fax Setup .
  3. Press Enter .
  4. Press the right arrow until you see 4: Paper Size .
  5. Press Enter .
  6. Press the right arrow until you see the paper size that matches the size of the paper in the paper tray.
  7. Press Enter .
DESCRIPTION AND SOLUTION – 2:
The media type sensor is out of calibration. HP has released a firmware update that corrects this problem.
1. Visit the Support and Drivers Web page and search for the driver downloads Web page for your product. To access to the Web Page click here.
2. Select your Windows version.
3. Locate and select the Firmware Update.
4. Follow the directions on the Web page to install the firmware update.
Hope this helps.
If you would like to vote for the answer, this will help the others to see the similar problems solved and also will be a satisfaction factor for me to continue helping you.
All the best.
I changed the cartridge on my machine. I got the
You can bypass the alignment on the machine making it use the previous alignment. To do this, press and hold down enter when it says press enter to align cartridges and then press setup.
Press enter to align cartridges message comes into the window of my HP combo machine and won't change. I reset the cartridges in their holders, turned machine off/on, no go. The machine still prints out...
You should load paper and press enter to align, The message will keep coming back until you let it do alignment or press enter and option buttons at the same time.
Will not fax
Hold down the enter button 1rst then press the setup button. This will bypass the annoying align cartridge problem. For some reason it does this because the cartridge you bought was refilled then sold again. Your welcome!
Message: Intall new ink cartridge. Ink Low
When you hear the fax ringing, press the start button. It sounds like you are not set to AUTO RECEIVE
2helpful
2answers
Replaced Ink Cartridge
turn fax machine off open cover and put 3 drops of 3 in 1 oil on the the big silver bar the ink cartridges ride along perform alignment and try to recieve fax if this doesnt work clean all the rubber feed rollers with isopropanol alcohol (rubbing alcohol) applied to a microfiber towel then try.
1helpful
Cartridge alignment
I understand that you are receiving the message to align print cartridges when ever you print.
This happens due to various of reasons.
Below are the possible causes of the issue that you are experiencing with.
The most common reason is an ink cartridge that has one of the following problems:
1.One of the print cartridges is low or out of ink. Black and all three colors must available.
2.The paper has already been printed on or is colored paper.
3.Protective tape on a new print cartridge has not been removed.
4.Contacts on the print cartridge are not meeting the contacts in the print carriage correctly.
5.Cartridge is remanufactured or refilled. Refilled or remanufactured ink cartridges may have been damaged during the refilling process or have clogged ink nozzles.
6.The print cartridge is defective.
So, make sure that ink cartridges have sufficient amount of ink and are of genuine HP should not be refilled or remanufactured.
Clean the cartridges by following the below given instructions:
Using a clean, dry lint-free cloth (a coffee filter works well), wipe the cartridge contacts, from the top to the bottom. The contact area of the cartridge should be rubbed briskly to remove the waxy lubricant material from the gold contacts. The contacts inside the printer may also require cleaning. Using a clean, dry, lint-free cloth, gently wipe the contacts, from the top to the bottom.
Align the print cartridges by following below given instrucions:
To align the cartridges from All-in-One
1. Press Setup.
2. Press 5, then press 2. This selects the Maintenance menu, then selects the Align Print Cartridge option. A page prints to confirm alignment. You can either discard or recycle this page.
Even if the issue persists, bypass the alignment by following the below given instructions:
Press Enter and Setup simultaneously when align message is prompted on the All-in-One.
Please remove the All-in-One Printer from the Power Surge Protector and plug it directly into a wall Power outlet, as the surge protector may not provide enough power to printer.
Please perform the step given below to power cycle the unit after removing the print cartridges from the printer:
1. Verify that the unit is switched on. Unplug the all-in-one from power and disconnect the USB cable from the computer.
2. Wait 30 seconds.
3. Plug in the power only
4. Repeat steps 2-3 two more times.
5. On the third time after plugging the unit into power, reconnect the USB cable from the all-in-one to your computer.
Reset the All-in-One to the factory default settings by using these instructions:
1. Unplug the power cable from printer when the printer is powered on and wait for 20 seconds.
2. Then, press and hold # and 6 while plugging in the power cord.
Continue holding until it displays Semi Full Reset message in the front panel of the All-in-One.
Note:
A semi-full reset will do the following:
The user settings to the factory defaults, Language and country settings on some models, Fax logs, Fax headers, Fax speed dial information.
This should resolve the issue.
Regards,
Lawrence
1helpful
11answers
Printer cartridge alignment
Another solution...we were having the same issue, but we found out that our black cartrige was out of ink...and when we replaced the cartrige with a new one, the "align cartriges" message when away once we pushed it one final time...we are in good shape now...yes, we are idiots.
k24674
Grand Canyon Tech
Grand Canyon Tech
